Best Aftermarket Headlight option?
CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRDORP, 2023 4Runner TRDORP
Hey Guys - Well this morning I noticed yet another green spot in the DRL on my Morimoto XB's and have requested another warranty replacement. This will be my 4th set so I'm done, that is if they respond read in another thread they weren't. Anyway looking for your experience with Form, Oracle, or anything out there so I don't have a repeat when I buy a new set.
I'm also thinking of just getting a set of Ford signature's has anybody heard of any issues with them?
Thanks!
Ford Bronco Best Aftermarket Headlight option? green spot
BoverW
J
Socal
ask for their xb as replacement instead of xrgb. No "discolor" issue.
CMillBronco
CMillBronco
Craig
Have you heard of them actually doing that?
broncobase1
Lincoln
22 Bronco Base
I'm very happy with my Base non-sig headlights. LED headlights that work and look great without any of the geeky nonsense. Something to be said for Fords minimalist approach to LEDs on the Bronco Base. It doesn't have LED panels all over creation like say KIA that cost thousands of dollars in a parking lot fender bender.
CMillBronco
CMillBronco
Craig
B22-2023
Houston
Thanks!
Oracle Oculus B-LED - they have worked great all around. I've had issues with other Oracle lights (and great support that solved them) but none with these. Bright wtihout being blinding, great for night trails. and good looking DRL ring. They don't necessarily work with after-market grilles due to how they mount, I've found.
Ford Bronco Best Aftermarket Headlight option? Light
ORACLE Terry
Terry
New Orleans, LA
Bronco, RAM TRX, Gladiator, Wrangler JL,
Give the ORACLE Lighting BI LED Headlights a look. The modular design really gives the grill an aggressive look! With 5,200 Lumens of high-quality Bi-LED projection, these headlights provide enhanced driver visibility in all weather conditions. Light focus is very important for driver safety and for others who can have their vision obstructed by glare. We are proud to offer the most focused & lowest-glare LED Headlights for the Bronco on the market.
Ford Bronco Best Aftermarket Headlight option? ORACLE_Lighting_Bronco_Mirror_Ditch_Lights
Here is the "Wall Test" for the Bronco Oculus BI LED Headlights. Check out the clear cutoff and almost no glare above the cuttoff and plenty of fill to light the road ahead.
Ford Bronco Best Aftermarket Headlight option? Bronculus_Wall_Test_2_1080x776_crop_center
JeffL
Massachusetts
2019 Challenger Hellcat Redeye / 2023 Base SAS
i swapped my base ones for the factory signature lightning. cheaper (ebay $600) and work as factory.
adcam
Mando
2025 Stroppe
I’ve had my Alpha Rex for more than a year with no issues.
Bikeric
Tulsa
2022 Badlands LUX on 37's
I went with the "cheaper" eBay lights and they have been solid for me so far. I can verify they still work properly every time I pull up behind someone with a clean car. I'm on my second set of Oracle tail lights because they stopped lighting all around, so I would be leery of using Oracle headlights.
Ford Bronco Best Aftermarket Headlight option? IMG_1294
