Bead locks
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Except you have to take the beauty ring off the wheel before removing or installing a tire onto the wheel.
Correct fellas? I admit I have not actually replaced my tires yet. So this is an intuitive assumption on my part.
I don't think that is factually correct, however removing the "beauty ring" makes mounting and dismounting MUCH easier, and avoids scratching it
iamcris
Cristian
Lakewood, WA
21 Bronco Badlands
The Ford performance beadlocks look amazing in person. That said I bought the Icon Rebound Pro beadlocks wheels which are apparently "Dot compliant"
Montana Bronco
Montana
Chevy
This is absolutely FALSE.
OP do not listen to this guy.
Tricky Mike
21 Bronco
After one initial retorqe, mine haven't loosened a bit. I posted about my experience here. Maybe very low pressures and very hard use require retorqing?
From my deep dive into this it would seem that if you get good metal to metal contact the torque should hold steady the longest. If they don't cinch down because the beads are too thick then you'll get movement and loosening.
I was able to get a couple of mine to fully seat flat and the rest touch in spots and I can get a feeler gauge in other spots. So I have a good experiment brewing.
swamp2
Oh yeah, gotta have metal to metal. I'd say got to have such, period.
Bikeric
Tulsa
2022 Badlands LUX on 37's
Howdy. I have the factory SAS package also on my BL. I have not taken off my beauty rings , but if I am understanding your commit correctly. The rim is predrilled with all the holes to turn them into true bead locks? Thanks
Yes, there are twice as many holes underneath those beauty rings. The Ford Performance rings come with all the stronger and longer hex head bolts you need (24 per wheel). Then you pry the tire bead to the outside of the lip and use the beadlock ring to smash down on it.
Mlarv
TN
2023 Bronco/ 2022 F150/ 1968 Mustang
Thanks I just learned something
