Bead Locks necessary for dune running?
None
Ubiquitous
Bicycle
Are bead locks necessary for dune running? Do you run your bead locks continuously or only when off-roading?
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
If you air down your tires a lot you'll definitely need them. It wouldn't hurt if you got them.
‘21OBX
90Bronco19
2022 bronco outer banks
Nope you should be good to 10-12 psi on sand. I found 15 to be fine at silver lake. Just make sure you air up before heading down the pavement.
  • Like
Reactions: Cat
‘21OBX
90Bronco19
They way bead locks work it’s not an easy off/on situation. Your tires get mounted different For beadlocks.
