Battery Terminal info
LeBronco
'19 Expedition Platinum
Ford Bronco Battery Terminal info unnamed
Does anyone have any info on what's going on here? Are the two open slots un-fused "full output" terminals? I see the little 3 amp fuse there and it makes me wonder if there is more here than meets the eye. One would think they are just accessory terminals and one could hook a winch or in my case an amplifier to either of them.
TRMFAM
OK
66 & 73 Bronco, 21 MDX A-Spec, 20 Raptor
Hmmm...first pic of this I have seen. I checked the owners manual and can not find anything. Pull the fuse and use a test light / volt meter and see if all 4 terminals stay hot.
I am guessing the smaller stud by the fuse is connected to the fuse but just a guess.
dgorsett
colorado
F250, Mustang, Explorer
Following...
LeBronco
agreed, I thought maybe the smaller stud was tied to fuse. I’m about to start try to start routing some wires today for the audio system so I will definitely whip out the meter.
ICUGAZN
Kevin
Woodbridge, Virginia
2019 Raptor
Any know the sizes of those screw posts around the main post? The ones used for powering accessories
da_jokker
Jeep Wrangler JKUR
Yeah that would be interesting. The post without the fuse might be for something like a winch. For anyone who bought the factory installed one, I want to with their battery post look like?
And the one with the fuse looks like a great possibility. I can see replacing that fuse with one a bit higher and using it for something like an amp or whatever. Maybe even a power distribution center inside the Bronco.
Bob Blaylock
Bob
38°29′ North 121°26′ West
2016 Dodge Dart
Speaking as a professional electrician—DO NOT DO THAT WITHOUT VERIFYING THAT ALL THE CONDUCTORS INVOLVED ARE UP TO THAT HIGHER CURRENT RATING! It could be that that 3-amp fuse is there because that circuit has conductors that are only adequate to carry three amps.
In fact, I wouldn't advise connecting anything to any of these terminals that is expected to draw very much current, without knowing how much current they are rated to safely supply.
dgorsett
colorado
I'm guessing that 3 amp fuse is not controlling that terminal, also see Bob Blaylok's post above. I think it may be the supply to the 'smart battery technology' that shuts things down if battery condition falls below certain parameters. Someone who actually has a Bronco might be able to verify.
Lifeliberty
Moonbeam👀
Columbus, OH
Did you get the auxiliary switches? I'm curious if all Broncos have that
da_jokker
Jeep Wrangler JKUR
Of course, if that fuse is powering anything. But from the picture it looked like the fuse was simply for that open post that had nothing on it. So any wiring coming off the battery you would be installing and could be as thick as needed.
Now if it turns out that fuse is powering something besides that empty post, then absolutely, don't replace the fuse with anything higher rated.
da_jokker
Jeep Wrangler JKUR
As a matter of fact, now that I'm looking at this picture even better, what do you do if you replace your battery with something different, like an optima. Are we locked into a specific style of battery terminals? I can't completely tell but it seems as if the battery is molded to allow a ledge for this distribution connection to fit.
jasonf
jason
california
f150
I have a warn winch and amp lead connected to those terminals and have no issues yet .
da_jokker
Jeep Wrangler JKUR
No not at all a worry. That whole thing is one piece that sits on top of the battery.
That's what I mean. It doesn't look like it sits on top of the battery, it kind of sits in a cut out area specifically designed into the battery casing.
Most batteries don't have that cutout. As long as the post is close enough to the edge that this thing can dangle off the side of a standard battery, there may have to be some creative hookups down the road as people replace their factory setup.
CPTRK
Patrick
Weston, FL
Jeep Grand Cherokee
I pulled the 3A fuse and all 4 terminals remain hot - so that fuse does not control the 4 posts. I noticed that there is a small wire leaving from below the fuse area - didn't test it because it's all wrapped but I'm pretty sure that's the line the fuse is connected. Probably some device/monitor/smart battery something that does not have it's own fuse in the main fuse box.
I used post 4 (the farthest to test some LED pods (3A total - no problems) - will use same post to power my 42" windshield light bar (20A) when I get it.
