battery tenders
jlee504
Wash DC
Cayenne
quick question, what battery tender are people using and which bolt is the negative bolt you are hooking it up to?
I just picked up my raptor and its hard to figure out in the instructions the hook up points.
thanks!
Squatch
For an individual vehicle, don't get any cheap tender. I use Deltran and don't trust any other reasonably priced consumer tender.
AKBronc49
Russ
Anchorage, Alaska
I'm happy with the Noco units I use.
Haelous
US
2016 Mustang GT, 2023 Bronco Wildtrak
I've been using CTek for many years without issue.
I'd also be interested in what negative bolt people are using for a permanent tender pigtail hook-up.
jlee504
Wash DC
Cayenne
I have a Ctek tender and it doesn't seem to be working on it. any pictures of the negative mounting spot would be great.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
The best I can suggest is a chicken tender. Ha!
I use NOCO, but their battery booster I keep in my Bronco. It's better new (couple of months, maybe?) and I've used it once or twice to help others - Works amazing, easy to use, and good quality. They're also a well-known brand, so I assume their battery tenders would be just as good.
Haelous
US
That's interesting. Do you have it set to AGM mode?
I've got it to work with the clips connecting it to the negative terminal after the BMS.
jlee504
Wash DC
Cayenne
I may have an older CTEK, it doesn't have an AGM mode..and it doesn't do lithium batteries.
it works on my defender but may need a new model.
Haelous
US
I have a MXS 5.0 and an older MUS 4.3, both seem to work ok with the clips. I only have a permanent pigtail on my Mustang since it sits for most of the winter.
Lifeliberty
Moonbeam👀
Columbus, OH
I use the deltran battery tender jr. Use them for cycles so I already have them. OG back in the day
Pos+ to one of the pos battery threaded posts on the battery
Neg- to the tang on the far end of the battery minder (which hangs off the negative battery post)
DUSTYcazOREGON
Craig
thanks!
Deltran is the only battery tender I recommend. I use it on all my vehicles, show cars, tractors, motorcycles. Your ride is always ready to go and it will lengthen battery life. I connect mine directly to the - and + posts and have had zero issues. Get an extension and you can have the lead come out the grill. Unplug it and you are on the road! This one is the one that Deltran and I recommend:
https://www.amazon.com/gp/product/B00068XCQU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The photo is from my Ranger.
Ford Bronco battery tenders BT2
Ford Bronco battery tenders BT1
Dusty
Mentone, CA
70, 71 & '21 Broncos
Fly by Nite
Walt
Pa
There are posts concerning where to attach the neg clamp. IIRC, you have to attach to the terminal away from the battery post. This way the vehicle system can monitor current going in/out of the battery.
I'll update if I find the info, or maybe someone else can verify.
I use some Deltran Battery Tenders as well. Also use a NOCO for higher charge rates.
