???Barnes 4WD Skid Plates????
I know a lot of folks use their diff and shock skids
B22-2023
Houston
I have a bunch welded on and will be adding more, it’s good and beefy where it needs to be.
NC_Oak
2024 4 door 2.3 sasq
Welded on you say? Interesting. Good to hear some positive feedback. Pretty sure I'll be placing an order as they're about to fab some more.
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
I have a set of shock skids from them, good design and quality build.
I wanted to protect the low connection points and after researching other manufacturers skids Barnes appeared to be the best. Installation was easy, good quality hardware, a great product.
Glade Runner
Everglades
VA
Yes
Everglades
I have their shock skids. Can recommend.
Ford Bronco ???Barnes 4WD Skid Plates???? IMG_1979
bassist
Northern VA
2024 Bronco Badlands w/Sasquatch Package
I have their shock skids but haven’t tested them.
I like that Barnes seems less likely to trap a buch of water and what not than most products on the market and didn’t require unbolting the shock.
I went with ASFIR for my cross member skids and transmission skids.
Bearcat1
Travis
2017 Expedition Limited, 2006 BMW 330xi
I have barnes shock skids, have held up great.
AdamF@IAG
Adam
Maryland
iagoffroad.com
'22 Bronco Raptor, '21 Bronco 2 and 4 door, '24 Ranger Raptor
As long as you're not riding on HOSS 3.0 Fox shocks. If you are (or aren't even) check ours out. We even include some plates to protect the lower links as well.
IAG Rock Armor Shock Skids
MNBigfoot
MN
I always found this quote from Goatman interesting in these regards:
"I am a retired KOH driver/competitor, and for 5 years have been a tech inspector. I see every single car that competes in KOH, in all classes. Myself and three other guys tech every car, I see every one of them. I assure you that NONE of them have differential skid plates. Look, I'm not trying to be difficult, just factual. Real off roaders do not run diff skid plates. It's pointless. Get a good heavy duty diff cover, that's what the real folks do."
