Auxiliary Wires at Firewall?
zburbn
2025 Ford Bronco 2Dr SAS 7MT
I’m looking to add a nudge bar and lights to my ‘25 Base 2dr SAS 7mt and was poking around to predetermine the wiring path and noticed these pictured wires at the driver’s side firewall area. The auxiliary switch option was not available when I ordered the Bronco so my question is are these indeed those wires, pre installed and able to connect to the now available factory switch Panel? In viewing the wiring color scheme, they match correctly. Would I need to just add the switches and have at it? Thanks!
Ford Bronco Auxiliary Wires at Firewall? IMG_7480
Ford Bronco Auxiliary Wires at Firewall? IMG_7479
Ford Bronco Auxiliary Wires at Firewall? IMG_7478
Dan-O
Dan
Fountain Hills, AZ
Yep… those stubbed wires are for the Upfitter switches which now is available. Unfortunately I don’t know what all is entailed in wiring up the switch but I think it’s got a plug for it up above the mirror. Not sure if fuses for it are already there?
helifino16
Ron
Mount Sinai, NY (Long Island)
The Fuses are all in-line. So, there's no need (as previously found) to replace the Fuse Box.
Ford Bronco Auxiliary Wires at Firewall? 1762442960547-6c
I believe that's what these are.
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
2022 Ford Bronco Badlands Sasquatch
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
Short answer. Yes those are upfitter switches wires. No its not as simple as adding the switches up top.
You'll need to replace your fuse box under hood with one for the upfitter switches, as well as the body harness that goes from the bottom of your apillar, up and around your windshield.
