AUX Switch Question
Acadist
WA
2023 BadSquatch
Just picked up a used Heretic light bar. Watching the video it calls to hooked up to #2, the 15 amp switch. I already have my RC amber/white fogs/spots hooked to #2,. #3 uses a 10 amp fuse, can I switch the fuse to a 15 amp?
WarthogJr
'21 Bronco Black Diamond
Maybe. The size of a fuse in a circuit needs to be appropriate for the gauge of wire. If a circuit was originally intended for 5A, the wiring in that circuit will be small. If you were to throw a 40A fuse in that circuit, the fuse won’t blow if it is exposed to a 35A load, but the small wiring wasn’t designed for that big load…so it would heat up. Check the wire gauge on the two circuits you’re considering. Might be ok. Or you may end up with a Bronco-B-Cue.
CitrusBronco
Everglades
Citrus county, FL
Everglades
The answer is no, you risk a fire.
hilmar2k
Doug
Hudson Valley
2014 Audi S4, 2020 Lotus Evora GT
Is switch one in use? That'll work.
Area51BS
Ron
Badlands non SAS 4dr 2.3
You can use the switch you prefer to trigger a relay connected to a power source/wire appropriately sized for the load. Source could be a fused line you add right from the battery.
Beggsie
2024 Bronco
As others have said, no. Not only is the wire gage too small, but the relay isn't sufficient either.
Bschurr
NY
Just use an appropriately sized relay to energize the circuit and you can use any Aux switch.
This is the correct answer.
No, you cannot just make the fuse bigger.
But you can use any switch to drive another relay and that relay can be as many amps as you need. Relays require just a fraction of an amp to drive.
  • Like
Reactions: wgw
hilmar2k
Doug
Hudson Valley
Or use switch one (if available).
