Auto Start/Stop Only Functions Intermittently
JT58Bronc
JT
Fl
I brought mine into the dealership when my start stop was not working as good as it used to. Bronco was approaching 3 years old at the time and I thought it might be the battery and was hoping to get a replacement. Nope, they tested everything and everything is fine, charging system is charging as it supposed to be. My Bronco sits a lot so dealership said It needed to be driven more to fully charge the battery. I charge the battery on a trickle charger now when it is idle a couple of weeks now and the start stop works fine now. I will point out that when it is very hot out it will not work. So, as already stated there are many factors involved for it to operate or not.
Lej512
60th Anniversary
Larry
Queensbury, NY
2026 Bronco Outer Banks Sasquatch
60th Anniversary
I took delivery of my 2024 Ford Bronco Badlands on Feb. 1, 2024. Up until now everything has worked perfectly on it. Just the other day the auto start/stop feature has begun to act up a bit as the feature is now only functioning intermittently.
I know that many folks on this forum have disabled this auto start/stop feature through various means, but believe it or not I actually like the feature and want the feature to function as designed. Attached are a couple of screen shots of the instrument cluster of my Bronco when the feature is not working.
I connected my Noco Genius 10 battery charger and when it was finished charging the battery was at 12.8V. So I took it out for a good long drive of 35-40 miles or so today around town and the auto start/stop feature was still not working. After running a couple of errands the auto start/stop feature started to function again and then when I got home it stopped working again. I am not sure what would cause this type of intermittent behavior. Perhaps a bad connector somewhere or a faulty computer module or perhaps the battery is defective?
When I got home my battery measured at 12.4V so are my voltage readings normal for this battery? It is sort of ironic that I want this feature to function as designed and I see many threads on this forum where Bronco owners are trying to disable this feature.
Any ideas, otherwise it will be an appointment with a Ford dealership to let them sort it out.
I had a 2018 F-150 Raptor that did the same thing. A/S/S rarely worked in the colder months and I guess it was because the battery was just below what the system wanted to see. Not a fan of A/S/S anyway so I never bothered to take it to the dealership. My 2023 Bronco BD works fine. I've been re-programmed to push the override button everytime I start the vehicle.
