Are you running regular or premium gas?
DETT
93 premium every fill up so far in the 2.7. averaging about 18mpg.
Getting 18.1 lifetime on 87 only. Just passed 7400 miles.
Hyfly
Idaho
BRONCO
Is ethanol free better or does it matter?
I don’t plan to save a few cents on gas on a $50,000 vehicle.
I plan on premium or ethrnol free if there are any benefits.
BigMeatsBronco
Allan
2021 FE 2 door
Only premium and sometimes an E-85 mix. đź’Ş
ocbucks1
Ron
CA
Toyta
You guys going basic gas or using premium when you fill up?
Premium is about 5-7% more. You get better mileage with premium. Do the calc. It can offset the difference. Maybe not 100% but with other benefits for the engine, I think it’s a no brainer and a really maintenance decision.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
I have used 87 regular forever and in my last two 2.7s. A fresh tank of premium does make a noticeable difference power wise when in the Bronco (couldn’t tell in my last two F150s) I have used it. That has been when I am going off road and may work it a bit harder. Has plenty of zip for every day driving with 87,
JFelty
Minnesota
Mustang Mach E
This is what our driveway looks like right now. We had the Mach E long before the Wildtrak and yes we are splitting time between the two.
Ford Bronco Are you running regular or premium gas? 20220312_102854
Opticnerve19
New Jersey
Infiniti qx60
How does the soft top hold up in the cold winters
D-R0CK
Las Vegas, NV
2022 Bronco Black Diamond
Running Costco 93 in my BD 2.3L non-squatch and getting 21 mpg.
JFelty
Minnesota
Mustang Mach E
I have had convertibles before and this one is warmer than all of them and the noise is about the same. 1 snowstorm and no snow inside.
Compta38
Alabama
Ford Fusion
I'll be doing regular...the cost of gas is too high for premium right now. When I can get higher octane for less than $3 a gallon I'll go back.
Bt_ostate
Oklahoma/Colorado
2021 Ranger Tremor 2021 Bronco 4-Door FE
I've always run premium in my ecoboost engines. But it's a personal preference.
I prefer maximum performance(hp/torque)and putting the best I can in it, so if anything ever occurs I know I tried my best to prevent it.
Bronco Don
Don
Rialto, California
Tacoma 4x4
I have been using 87 , I have 5,000 miles and seems fine. I have 2.7 and average 18-19 mpg
Wanted33
Down south in Dixie
IMHO ethanol has no other purpose than to extend the amount of gas used in the states. There's really isn't advantages to it other than that. You will get better gas mileage from ethanol free, but the added cost of straight gas (which I really don't understand) will negate any added mpgs. I figure if the manufacturer says I can run regular ethanol gas, and everything will be fine, that's what I'll run. In my case my butt dyno cannot feel any difference in the power when using 93 octane. But, that may be just me. It's really what someones preference is when it comes to the gas they run.
My thoughts are that corn should be used for food, not fuel. :)
