Are you running regular or premium gas?
lapazleo
Indiana
2022 bronco badlands
Speaking as someone who used to haul gas as I can tell you many times regular found it's way in to premium storage tanks and vice versa. Usually by accident but sometimes on purpose. High end stuff like Amoco ultimate is the same as Circle K cheap stuff only with an additive you can buy at Autozone and put in your self for much less money.
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
I’m sure 85 would work just fine too.
The Owners Manual Supplement "recommends" 87, unless using it off roading or towing, then 91+.
nkyhunter
mark
nky villa hills
2022 BRONCO,2021 JL RUBICON,2022F150 TREMOR
at this point in time on gas prices, the lowest cost wins which is 87 octane
CoachTee
Teresa
Jensen Beach, Florida
2021 Ford Bronco Badlands
Thank you for posting!
Long ago, my father (long deceased) had preached to me about octane levels and constant & long term use of high octane on a truck would harm or shorten the life span. He had worked his whole life at the Ford Transmission plant in Livonia.
I'm no mechanic, but something about burn level?
Wasn't sure if that still held true.
JFelty
Stroppe
Minnesota
Lincoln Corsair Hybrid (Plugin)
Stroppe
Was this picture taken at Christmas or do you still have your Christmas lights and decorations up?
It's cold in MN in the winter and or maybe Im lazy in the winter. Either way it is winter and they all come down when it is warmer. This week it should hit 50 and they will all be gone.
JFelty
Stroppe
Minnesota
Stroppe
$85 to fill up the other day but I'm still sticking with premium (93, locally).
I am afraid to get below 1/2 a tank so my fill ups have bee right around 50$ each time.
Fordmanbob
Bob
KS
2018 F150 4x4 supercrew, 2006 F350 4x4 superc.
What a moot point
JohnnyBronco
Pennsylania
X4
Back in the day when engine control management was setting timing after changing points and rotor and only changed due to wear of distributor shaft and burning of points then your dad was inking correctly that you run the lowest octane that does not cause knock as otherwise you raise temps with no corresponding power output.
But with anti-knock sensors and smart ecm adjusting timing several times a cycle you can (and I do ) run the highest octane available for the highest sustainable power
As far as cost of fuel, do not think in absolutes but in differences between grades. Suppose 87 is $5.00 and 89 is $5.20, 91 $5.40 and 93 $5.60, even at a 60 cents difference between lowest and highest grades to fill a 20 gallon tank at 60 cents diff is $12.00, yes a lot but if you are only comparing 2 adjacent octanes at 20 cents, that's $4/tank, sure still a lot but but @ 360 miles/tank is just over a penny a mile. And you can save that $4 buy forgoing one Starbucks per tankful
mamamoose
Nikki
Youngstown, Ohio
2002 Ford Taurus, 2019 Civic Type R
I'm going to run 89/midgrade in mine.
Xtermin8
Joe
2022 Ford Bronco Wildtrak
I will be running 93, but that's only because 93 at Costco is cheaper than 87 everywhere else. If the gas prices keep going up, I'll have to use 87, which is still under $3 a gallon at Costco.
These are funny to read today. :cry:
FlyingBronco
The Don
Orange County, CA
91– Yaa the current prices are a bit extreme but I didn’t buy this rolling brick to pinch pennies on fuel. I save a bit of cost on oil changes.. found a good price and change it myself. Feels good to learn new skills and wrench on things.
Ser Arthur Dayne
Jeep Wrangler Rubicon
I filled up mine for the first time a week or two ago.
Couldn't figure out how to get the damn door open.
I damn near ripped the door off and realized "Something ain't right" here... I am going to break this ...
So I did what everyone does to get through life these days.
I humbly pulled out my phone , Googled it, and watched a 45 second Youtube video to learn that you push the door open instead of pull the door open.
===Seems Legit...
