I had the same thought and just used a fuse tap for my switch. The switch gets power when the vehicle is running and I’ll just turn it on when needed. But! I also installed air tanks. I’m now considering using an aux switch to turn the compressor on when getting close to the air up location to allow the compressor to cool before filling tires. (If you go the tank route I’d suggest throwing in a check right after the compressor. I was losing a little pressure back through the compressor. The check doesn’t seem to be affecting flow at all)Curious as to why people are using an aux switch. Unless it’s a convenience issue i see no advantage of using an aux switch.
