Any way to remove the speed limitations...
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
Still locked at 102mph after the PCM tweak..
It appears you'll need a tune (and z-rated tires) to get rid of the governor unfortunately.
I have Never seen z rated off road tires. I will probably pick up a set of BFG for my next desert run , since my current Coopers are only Q rated at 99.
Min_Ahn
Min
Denver, CO
2019 Ford Mustang, 2023 Ford Bronco
I was over exaggerating lol these bricks won't ever reach that speed :ROFLMAO:
Even BRaptors (governor at 120mph) are equipped with BFG K02 which has an R rating (106mph) so yeah BFG should suffice.
Ducati1098
The way my 2 door 2.7 pulls, I would be shocked if it was drag limited to 125, but rather limited by my personal attachments.
Agreed. I have zero doubt my 2dr 2.7 could surpass 125 without a limiter also.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
I did 75mph once in my 8" lifted '82 Ford F-250 with the gimpy steering, granny four on the floor, and leaking master cylinder. We almost died (that truck had many problems!). Also, that one time in the rain on the overpass, or turning the corner when we almost took out the mailbox/tree/random parked car, or when... 😅
buzzcutt2
FL
I did 65MPH in my 89 YJ with 4" lift on 33" - that was scary!
SCB FabWorx
Aledo, TX
2018 Cadillac CTS V
Whipple Stage 1 Raises it to 120 mph limit. So far I chickened out at 112.....:LOL:
SS Bronco
Shayne
Loomis CA
Go to know. I’ve held mine at its limits off road many times. 5” lift and 37” definitely makes 101mph a little more of a challenge.
Tex
Cliff
San Angelo
2.7 or 2.3 are not going to get to 125 (delimited)...
Aerodynamics are the dominant factor which are largely irrelevant below about 50-60 (you nor the engine "feels" that drag) but from there and up it increases really fast. These are bricks...
Curious to know what the drag coefficient is on the Bronco specifically.
I've had it to 107 with a steady 20mph quartering headwind, accelerated just fine up to the limiter.
Mine is certainly not a poster child for low drag, high speed, or even fuel efficiency.
swamp2
I had to use both Cd and frontal area to calculate top speed (obviously). I'm pretty sure I couldn't find either for the Raptor but found Cd for a non Raptor and then did a very rough calculation of the frontal area or increase in frontal area. I can let you know the numbers I used later when in front of my laptop.
Tex
Cliff
San Angelo
Sure, no rush, just curious what kind of values you were running.
swamp2
I used:
Cd = 0.55
Frontal Area = 38 ft^2
IIRC, I found one and or the other for a Wildtrak and did a rough calculation to get the increased frontal area for the Raptor.
5.0 to 2.3
Those YJ leaf springs are very nerve wracking at higher speeds for sure lol. My old 04 TJ was lifted on 3 inch BDS suspension lift and anything above 90 was no go territory with terrible handling, terrible wind noise, etc
Ducati1098
I used:
Cd = 0.55
I’m far from an expert in aerodynamics, but just looking at other vehicle measurements, I feel that frontal area is a very high estimate
I brought this up in a different post a while ago, and while maybe not exactly the same, the frontal area of an H2 hummer is only 26.5
Tex
Cliff
San Angelo
I used:
Cd = 0.55
Gotcha, so you were factoring it for the Raptor then?
I’m far expert in aerodynamics, but just looking at other vehicle measurements, I feel that frontal area is a very high estimate
My guess would put a 2dr Bronco somewhere between 25 and 28, and the 4dr at 28-32, just loosely basing it off figures for similar vehicles such as the XJ, TJ, and JK 2/4dr, but one of the problems here is that those figures are based off stock vehicles with stock suspensions. Lift any of those vehicles, add bigger tires, and frontal area will naturally increase due to the tires and drivetrain being more exposed to the air. That's why you'll see such a variation in mpg between the tiny tire 2dr broncos and 4dr sasquatch broncos. Cd is a little trickier, as the Bronco should have an equal to or better Cd than any Wrangler on the road today simply due to its more aerodynamic a-arm setup with superior body aero considerations than a new Jeep would have. Just to put it in perspective, the difference between a hard and soft top on a Wrangler changes cd by only .03 but frontal area increases by .5sqft, so the relationship between the two is also important. Coincidentally, .55 is the Cd for an older TJ, so I'd probably place a 2dr Bronco a little lower, maybe at .45 or so.
38sqft would be where you'd land if you took the height and width, roughly 41.5sqft depending on the source of those measurements, and split the difference between a generic frontal area multiplier of .85 for typical passenger cars and 1.00 for trucks, around .9-ish. It's a fair estimate and rule of thumb for basic efficiency comparisons between vehicles, and that factors in wetted area for a typical length that you'd see as well as all the other nitpicky stuff (cars being shorter and less undercarriage exposed, trucks being longer with a draggy bed and whatnot). But when you start calculating drag limited top speed, it really does need to be super precise, and those figures seem a bit high to me. But that's just my own ballpark estimate and what I've observed in practice, as I certainly don't have accurate numbers for any of it. I doubt any of us could provide an actual figure for a drag limited top speed on a Bronco without wind tunnel data anyway.
swamp2
My figures are estimates. Both though will be significantly different than for a 4dr Wildtrak. Using 0.5 and 36 yield a top speed of 132.
