Any Fox / King review yet?
Primed_in
New Mexico
Ford Edge
It was but it was not related to geometry. I purchased rpg tie rods and the bolt they provide to go into the rack was to short. It did not have enough tread engagement and it stripped out.
Could you elaborate on the fix for that? I have a set of those tie rods coming in
Oscargrouch323
Oscar
Los angeles
ac-fab.com
2022 bronco
Not sure if they fixed on their tie rods. The bilt that holds the clevis to the steering rack was to short. It would only engage about 2 threads
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
My initial review from recent King install on another thread...
Great install. I have the Bronco King's 2.5 on my Badlands.
I had to have my off road shop install mine then went to Ford for alignment. For those of us without the skills, time or ambition to self install I paid $475 for the install plus I had to have an alignment after.
Just had them installed a few last week and went off roading on a 25 mile loop of old mountain fire trails with some washed out ruts and rocks. The King's performed great. The trail I took was on is very similar to the higher speed trails at Nevada Off -Roadeo. I noticed their Badlands SAS would bottom out and I exceeded the suspensions limits a few times. (At Off-Roadeo, I was the lead Bronco so our instructor let me drive faster than typical.)
I knew after my Off Roadeo trip, I needed to upgrade the shocks or live with slowing down...My set up with the King's on a similar trail to Off Roadeo this weekend while driving faster, I never felt like I was even close to the limit of the shocks. On small chop they are very smooth, but on the big whoops or washouts I found they excel.
Looking forward to trying them on higher speed desert runs, just waiting for cooler weather. But even on switch back mountain pass trails where you can get up to 40mph, the shocks make a noticeable difference. Noticeably a lot more comfortable off road and when the rut pops up in-front of you, you just soak it up.
On-Road,,, A little stiffer than stock BL SAS shocks, but in a good way. Not hash, just noticed less body roll and overall stiffness had a slight increase. But off-road they had the bronco performing at a noticlby high level and gave me way more confidence.
I had the adjuster on the King's set in the middle of the range.
fordguru
Riverside ca
Gen 2 raptor, 20 expedition max, bronco ba/sas 2.7
On-Road,,, A little stiffer than stock BL SAS shocks, but in a good way. Not hash, just noticed less body roll and overall stiffness had a slight increase. But off-road they had the bronco performing at a noticlby high level and ga veme way more confidence.
I had the adjuster on the King's set in the middl e of the range.
I.
I can’t find the install thread can you post? Thanks
Losy
Long Beach, CA
Hi,
I had my off road shop do the install. So I won’t be much help there.
Myke98
San Diego, CA
21 Wildtrak
I.
Go to the youtube Baja Designs channel the have a really good install video. The only thing I would add is knocking the lower studs on the front coil overs out to make them easier to remove and not sure if you need to remove the steering shaft as they show. Other videos do not note that.
Myke98
San Diego, CA
21 Wildtrak
I have switched to Kings from the stock SAS setup on my Wildtrak. The King preload is the same as delivered and I have the adjusters all the way out.
My initial impression is that the Kings have less initial plushness than stock. I expected this and it rides more like the sport suspension I have in my Audi now instead of the cushy stock feel. I can feel more small imperfections in the road than before, but it is a nice ride. This is suspension made for offroad. I do think that as described by someone else it will be better for highspeed off road than stock.
I may have went Fox had the option been available because a few suspension tuners have stated that the Fox set up can be tuned for a better on-road feel but still be really good off-road.
Thanks, Mike
BDS Suspension
Coldwater, MI
bds-suspension.com
'21 Bronco
FOX is taking the slow/steady approach to development. Prototype coilovers exist and have been installed on a number of high profile builds. They're expected to hit the market soon.
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
I have them 'pre-ordered' Can't wait to get them on.
ScumbagTakumi
Sean
Porter Ranch, CA
AE86 Corolla (S2K SWAP), 08 Acura MDX AKA THE GOAT
We just got a couple sets of Kings with adjusters in at the office. I am really liking how they set up the coils and the fit up looks aces. Saw some of these out in the wild and they are definitely pretty killer. Hit up Shock Surplus and ask for the Bowman discount, and we can hook you up.
https://www.shocksurplus.com/
