Ambient lighting
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
Anyone else having issues with the ambient lighting in the footwell? I will turn mine on then a couple days later it keeps resetting off and will have to turn it back on. I brought it to the dealer when I had an oil change done and surprise, surprise they said NPF.
Not a huge issue but it’s just annoying
mbdlds
I found this happens if I reset the audio unit by holding the power button and track forward buttons. I was doing this fairly regularly you get Android Auto to connect, and it would switch off ambient lighting every time.
Cornbred
Georgia
17 F-250/Edge, 14 F150,202? Bronco Base/Raptor
I just use rock lights in the footwells. Wired to auxiliary switch, any color and can change brightness with app.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello, Andrew! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this concern. Thanks!
ChrisB351
Shreveport, LA
Ive noticed mine will turn off sometimes as well. I think it has to do with headlight settings. I leave mine in auto position but sometimes Ill change it. That seems to be the only thing that makes sense.
vbrad26
Vance
FL
VW's, an old Range Rover and now a Ford
This has happened once in the 7 months I've had it, and I think it happened pretty early on.
Not sure what may have caused it, but it has not happened in a while...
Dubsesd
Dubsesd
Andrew
CT
I’ll see if that is the culprit thanks.
Dubsesd
Dubsesd
Andrew
CT
Mine will happen every two days about.
Snowdogyyz
23 Ford Bronco Wildtrak
Yes. Happened on my 22 Badlands and happens now on my 23 Wildtrak. Haven’t noted the frequency or time between when it decides to shut off. I just know I notice it off occasionally and have to go back into settings to turn it back on. I leave my lights on auto.
j_marinelli
Spring Branch, TX.
I'm curious to see if they find the cause as this happens to me too. Other items that have occurred frequently is Andriod Auto won't connect and front camera would randomly black out.
That said, camera and AA haven't really had any issues in a good amount of time. I honestly don't know if my ambient lighting is still having the same issue as its been daylight outside when I leave for work. Fixing to hit a long road trip and will probably be able to see how the ambient lighting does.
ChrisB351
Shreveport, LA
my AA will freeze the screen at random. I just disconnect bluetooth on my phone and reconnect and it clears up
ColonelAngus
Jon
PA
2023 Badlands, 07 BMW 335i, 05 Saab 9-5 Aero
Mine did it once too, I had just assumed I shut it off like an idiot... although that may still be the case.
Bacchanalia
Tony
I'm having the same issue. I thought it was from resetting the system, but it happens randomly.
jrbreeland
Jason
Atlanta
Yes. All the time
