Amber DRL
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
I referenced the FORscan Google doc. had somebody make the change. They work during the day(Amber, Blink), but when headlights come on they still stay Amber and won't blink.
Yeah they didn't do it right. All you have to do is go into the plain english side of forscan (not the as-built long number side) and under BdyCM change "Right(left) Front Turn Lamp Usage" to "Turn and DRL" from Turn Only. They might have just selected DRL or something else.. I don't recall all the available options but "Turn and DRL" is what you want.
jensht
Germany
2023 Ford Bronco
Sounds like they changed the coding to 0404 instead of 0101. The 0404 coding makes them stay on permanently and disables the blinker.
BigDeuce
JayCee
The Sip
1971 Ford Bronco
Ok, thanks. I'll get with them and reload it.
BigDeuce
JayCee
The Sip
1971 Ford Bronco
Thanks for the info!
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
To be clear you can do it from the as-built side of forscan too with the code the guy mentioned just above but its simpler/harder to screw up from the other side of things IMO
BigDeuce
JayCee
The Sip
1971 Ford Bronco
Wanted to update-
We made those changes, and now everything works properly.
I appreciate the support and all the info on this forum, y'all have a good one!
