Horizontal Amber DRL Forscan tutorial / easy instructions
TTUHoopsFans
Bill
Frisco, Texas
2023 Ford Bronco
I’ve tried to follow everything I could find here on the forums but I can’t get this to work. I have a ‘23 OBX with high package.
can anyone please link a video tutorial or easy instructions? I’ve tried the BdyCM as built module and the other one too. Not sure what I’m doing wrong! Thanks!
Ducati1098
You should only have to change 1 thing in the BCM
726-43-01 The first line should be 0101
If that doesn’t work try 0404. One of those will work
TTUHoopsFans
TTUHoopsFans
Bill
Frisco, Texas
2023 Ford Bronco
Thanks. When I changed it to 0101, it automatically changed the last 4 numbers too. I tried to change them back, but as long as I had 0101, it would automatically change the last four numbers to like 0174. Either way it didn’t work.
I’ll try this whole process again later tonight.
Ducati1098
Don’t worry about what other numbers it changes. Just change the 0101 and write it.
Be sure to remember the stock numbers just incase though.
Also remember, at night or with the headlights on, they will revert back to white, not amber. There is no way around this. Also the amber will only show up when in gear, because that’s when DRLs turn on.
Loeb
Loeb
Tacoma
'25 Badlands
01-01 is probably what you want. 04-04 disables front hazards at night.
see:
Not sure if this was the change or something else, but I was trying to do this and it worked… except the turn signals would not work with the headlights at night any longer and I didn’t notice it for some time
so just a note to check that out
