ALL FLUID SERVICE PRICING / SPECIAL NEEDS?
B22-2023
Houston
2023 Base 4 door 2.3L, 35k Mi.
I received dealer pricing for a fluids service:
Lube, Oil and Filter Service - $172.42
Transfer Case Fluid Service - $333.00
Transmission Service, with Fluid Filter and Gasket - $1488.66
Brake Fluid Exchange Service - $310.54
*Coolant exchange - Didn't get pricing
Questions:
* Do any of these require a dealer, with some special equipment?
* I saw the Trans fluid replacement needs you to cycle it on or something to adjust the level of fluid you swap in.
* I read somewhere the brake fluid also needs some specific steps?
* Any recommendations?
I understand most of these are not required until over 100k miles.
I also had a Escape trans implode on me at 60k miles, so i figure why not replace all the fluids.
As has been said, nothing a dealer has makes them uniquely able to do this service. People like me on this forum do it in their driveways all the time with supplies from the auto store or online.
Are you in Montclair NJ? Because those prices look like they are for the bridge-and-tunnel-crowd coming over to save on sales tax! Just go in and see these guys https://www.parkstreetauto.net/, or others like them around the area. A certified independent shop that is ASE or whatever certified can knock all that out for you - and probably let you bring your own fluids (specs and capacity in the manual) to save more money.
lmarchetti
Luke
Thanks
That's my question.
Which of these involve a computer / dealer system - and which can my local garage handle.
Do you have specifics?
Extended warranties do not cover routine maintenance
I think we are having a bit of a mis communication, probably my fault.
From my understanding you had a concern that your transmission for example might fail and you want to try prevent that by increasing the maintenance on it more frequently than the service manual is requiring.
Why not address the concern directly by getting an extended warranty to cover a transmission failure and do the regular service intervals?
For example, the manual calls for trans fluid at 150,000 miles. If you do a trans flush every 35K instead of 150K you would spend $1488.66X4= $5,954.64 at that 150K mark instead of $1,488.66.
Consider sticking to what the manual calls for, wait till 150K and instead of getting those extra flushes (saving $4,466) purchase the extended warranty so you don't have to worry about your transmission failing. Those savings could get you a 10 year 125K extended warranty, that covers way more than the transmission.
Ford Bronco ALL FLUID SERVICE PRICING / SPECIAL NEEDS? 1746052070491-hk
Your math adds up and it makes complete and total sense
But it relies on you having faith that ~if~ you did have a failure that it would be covered by the warranty.
(Of course, the obvious counter to my own argument: changing fluids early requires you to have faith that changing the fluids early and often will prevent a failure that may or may not occur regardless of the fluids status)
zoober
Robert
Rossville, Tn
‘24 OBX SAS LUX
I’m just here to wonder on pricing. At 5,000 miles, I got my oil changed by the dealer I bought from, because I’ve got 2 “works”certs. But the invoice for the works (oil and filter, 3000 or so 😏 point inspection, 5 tire rotation and pressure, all fluids checked and or topped - washer- etc..) was $87.
is service that much more expensive in Tx than Tn?
or should you dealer shop?
NC_Oak
2024 4 door 2.3 sasq
You never answered ducati - did they really quote you $1400 for tranny service?
Bruno
Bruno
Bruno
Sierras
ok - whatever I just like to take care of stuff not replace stuff under warranty
Bruno
Bruno
Bruno
Sierras
CarbonSteel
Colorado Springs
2023 Carbonized Gray
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Ducati1098
If my garage down the street does it my trans flush will likely cost a few hundred all in.
I was concerned the computer might need to be reset or some BS.
Ill just study the voluminous post by :
@CarbonSteel
https://www.bronco6g.com/forum/threads/change-driveline-fluids-early.83929/
No computer is needed for any type of transmission flush or drain/fill.
The only thing needed is transmission temperature which you can see on the cluster.
Just make sure they use the correct ULV fluid
userdude
Denton, TX
2023 2dr Badsquatch
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I'd tell you but its on a need to know basis
Well, I certainly don't need to know, not even interested any longer! lol
KABQ
Aaron
Albuquerque, NM
Not sure why this thread went the way it did, but all of that can be done by a local shop for WAY cheaper than the stealership quoted you. If you want to change fuids early, go for it. If you don't want to do it yourself, that's fine too.
Not sure why you're getting roasted because your dealership threw a stupid number at you, but at least now you know your dealership sucks!
