Alarm keeps triggering
Ducati1098
Thank you! Did not see that. Is the assumption that they changed the switch design?
I'm not sure. There was no part number change for the latch, but since it was only for build dates within a few months I would guess that they just had a bad batch of hood ajar sensors and it's since been straightened out.
2023bronco
location
vehicles
I fall into this. Pondering whether to just replace it myself. The alarm goes about an hour after I shut off the vehicle.
Edit: I bought on for $25. Sounds like an easy, permanent fix.
You're the man Ducati !
Ducati1098
Yeah they’re pretty cheap luckily
Gityup
Ed
Wyandotte mi
2008 Suzuki SX4
Hi I had bronco installed with the the perimeter plus and it’s been going off from that first day . I can’t pin down if its temperature or the length of time it takes me to get out of the car and arm it . Also if I return back later to get something else from any door , it may go off . Only thing certain is that if it decides to go off it will go off in 15 seconds or 30 seconds .
it also can go off after I use fob auto start , but that happens rarely
Gityup
Ed
Wyandotte mi
2008 Suzuki SX4
Alarm never goes off randomly after the latest of 30 seconds
2023bronco
location
vehicles
I finally got around to replacing the latch today.
Pretty simple: Remove grille, flares, painted trim above the bumper, and headlights, and remove the bolts holding the upper grille shutters so it could be pulled forward for access to the latch and wiring.
I taped around my old latch before I removed it, to give me a starting point for adjustment, and it told me how bad the factory adjustment was. The hood is poorly made too. But I managed to make the hood presentable and have no hood flutter. And, so far, no alarm waking up the 'hood.
Sighlense
Upstate NY
2015 Mustang GT - 2022 Bronco Wildtrak
Can this be turned off thru FORScan? Wifes alarm is going off 3 or 4 times a day.
