ATLBronco75
Tom
Atlanta GA
2.7 Badlands
The Factory ambient lighting brightness can be adjusted on the touch screen. Mine was set to the lowest setting when I got it. It also looks like your rear dome light is not on. Here is mine and I have it set about a little over a quarter way on the slider.
Yep this is what I was hinting at.Mine were so obnoxiously bright I had to turn them down.
Theherofails
Theherofails
Thomas
Phoenix
Ive turned it up all the way and then a tad bit more.. Ill have to look into the rear dome light - mine is nowhere NEAR that bright. Its ok for the cargo area but not the back seats. Almost completely dark.
GPBRONCO
Howard
Dallas, TX
2011 Flex, 2015 FX4 F150
This is the lighting kit used.
TOTAL INSTALL TIME: 45 minutes.
(I know the guide is messy, consider this a beta until I figure out formatting to a tolerable level)
This is a "simple" guide to installing interior ambient lighting, as the Bronco w/hard top is VERY dark inside - especially once your windows are tinted. The goal was to get it as close to factory while keeping the cost affordable. This is footwell lighting and there will be a different tutorial for proper cabin lighting to replicate the missing dome light. The linked lighting kit is fully bluetooth and you control everything from your cell phone.
This install uses upfitter switch 6 (Yellow/Orange) as a manual bypass but lights will turn on and off with the vehicle if left in the on position. I did this because there are times when I don't want a lot of interior light - doors off, for example. If you don't need the bypass, your install will vary slightly. You'll need to tie into a 12v power that turns off with the vehicle. Center console is an 'always on' power source, so not ideal.
The install vehicle is a Badlands with wash out interior. This matters more than you would think - how you attach the LED lighting is going to vary based on your vehicle interior. Leather interior with carpet will likely need different LED placement below the seats. I would likely use the same method but attach to the bottom of the seat instead of the floor. No chance of getting anything sticky to stick to the vinyl, so bottom of the seat is out.
Tools and Materials Needed:
  • 10 feet of stranded 16 gauge wire. Trailer wire would work fine. I used blue for lighting.
  • 1ft stranded 16 gauge wire for ground.
  • 3M EXTREME install double sided tape
  • Crimp Solder connectors for 12-16 gauge wire & heat source to heat shrink wrap.
  • 1 Ring style connector for Ground lug
  • T15 bit & Screwdriver (not pictured)
  • Shrink Wrapping is optional and would only be needed if soldering wires instead of using connectors
  • Sharp knife or scissors
First, some reference material.
Aux6 is Yellow/Orange and we will be attaching
that to Brown/White under the hood, which in turn
is found behind the glove box. I used crimp solder butt
connectors, which are weatherproof. This gives us 12v
Follow the instructions for your connector choice (or solder).
There are two wires behind the glove box that are part of the upfitter switch system.The brown/white wire now has 12v and will power the LED system.
To remove the glove box, push in on the tab located on each side of the glove box and let it drop down out of the way.
Next, attach your 10 foot section of 14-16AWG wire with your connector of choice. Here you can see the blue wire as I was connecting it to the brown/white wire from the previous step. This was taken prior to using heat to shrink the blue sleeve down onto the wires for a permanent attachment.
You'll want to snake the wire behind the trim in the
passenger footwell that houses the speaker grill.
This panel really isn't attached in any meaningful
way, so you should have zero issue sliding it under
the edge until you hit the section in the next step.
Start up top behind the glove box and slide it under
down until you hit the door sill.
This trim piece is actually the cover for the main cable channel for your Bronco. Grab with your fingers and gently pry.The entire panel will come off, exposing the wiring beneath it.
Continue to run the blue wire until you hit the rear
trim piece towards the bottom of the photo.
Slightly wiggling this piece will allow it to pop up
enough for you to continue routing the blue wire
until you hit the cut out for the seat belt, as shown in
next photo.
This is behind the B-Pillar, at the back of the passenger front seat.
The black object coming out of the cut out and leaving the top of
the photo is your actual seatbelt. This is going to be our exit point
(and entry point for a later step) for the blue 12v power cable.
At this point, we need to start installing the lights.
So now that we have power where we need it, we need to install the actual LED wiring harness. This is where things get tricky to explain. The LED kit in question is a Y wiring harness, and the center point for this harness is the rear center console, between the front two seats. You'll route one set of 2 LED strips to the left, and the other set to the right.
In the photo, you can see the 12v plug going to the control module, which exits and splits into the Y. Set the LED kit in the back seat on the floor directly behind your center console. This is the central install point. From here, you will attach the first LED strip on the left and right side to the bottom of the rear seats.
Chop off the 12v connector to reveal a black and red wire.
Black = ground
Red = 12v
I attached the control module to the rear of the console using a section of the 3M extreme tape. The included stuff is garbage. Make sure to clean the area first. Once your control module is placed, you'll want to shove the left extra wire under the center console to keep the install tidy. The loose cable gets routed under the trim piece attached to seat rail in a following step.
This small black screw (T15 bit) holds the trim piece on the back of the seat rail to the vehicle. I tested it with a multimeter to confirm a solid ground via the screw threads. This will be your ground point. I had to create a small ground wire, as I didn't have a ring connector that would fit the bolt shaft that would crimp onto the 16AWG wire.
Right here is where I attach the ground to bolt above after having scuffed the surface to ensure a proper ground path. This photo also shows what the extreme tape is for. Position a strip under(from the rear) each front seat, directly in front of the AC vent. Remove the included tape and press your light strip directly on to the extreme tape. Make sure you clean the floor really well first with mild soap and water to ensure proper adhesion.
I ran the power wire directly behind the light strip, using the same strip of extreme tape to hold it in place. I then zip tied the blue wire to the seat rail on both sides as a strain relief. Trim any excess wire and connect it to the red wire
coming from the LED control module.
If you have leather or cloth, you can also use the extreme tape to attach the light strip on the bottom of the seat, but make sure you leave enough slack in the black cables attached to LED strips. The seats move forward and backward, so keep that in mind.
Attach your 12v power using a butt splice crimp connector and tuck the excess cables/wires under the center console trim or the seat rail. I also used a zip tie to keep them from flopping around.
Driver side is done exactly the same way but you only have the black LED strip cable to deal with. Don't worry, with the seats in normal use positions, these LED strips are completely hidden.
Once install is done, use a knife to CAREFULLY trim excess black tape from around the light strip for bonus points (not pictured).
You're going to use the same method as above to route the black cable connecting the LED strips through the main bus channel to the front passenger and driver areas. (Same image as above for reference).
Passenger side will have the 12v power (blue in my case) and the black cable connecting front and back LED strips. Driver side will only be the black LED cable.
Reattach trim.
This is what your passenger and driver side should look like when finished with the rear install. These are the only two places that any type of wire or cable should be visible when finished.
The trim is so floppy here that it will never put enough pressure on the cable to damage it. If you are worried, just route it through the channel slightly to the rear that the seatbelts use.
Your finished rear install should look a lot like this (trim the tape once you are certain you like the positioning of the LED strip). I noticed the wash out flooring is quite loose and wavy under the seats.
For your front driver and passenger, it's a little trickier. You're going to use the 3M extreme tape again and attach the light strip to the thin edge behind your dash that faces down. I have yet to find a better mounting method, although this one is a little difficult to use. You'll have to zig zag the LED strip a little to route it around the OBD2 sensor (and a few other little objects).
You'll route both sides behind the trim, down to the main cable channel shown above. The driver side gets routed under the foot rest, which is attached to the trim.
Once you are done, go back and trim up any excess tape to your liking, tuck any loose wires under the trim, and you should have a completely clean install that is weather resistant. The location of the rear seat light strips was dictated by the fact that absolutely nothing sticks to the vinyl seating, so you can't just adhere it to the bottom of the seat. The LED strips are sealed, so shouldn't be damaged when washing out your interior. You'll never need to access the control module, but it's behind the seat if needed. Everything is handled by an app on your cellphone.
Absolutely no wires or LEDS are visible from the inside or out, doors on or off - The only visible wires should be 1-2" as it exits under the seats and enters the trim pieces, but you would have to move your seats forward and REALLY be looking for it. Be warned - the black EXTREME tape is PAIN in the butt to work with. You really have to take your time and be patient to keep it from sticking you or anything in a 10 foot radius to the vehicle accidentally.
I'll add a video here shortly to demonstrate it at night. I think I'll be doing video format tutorials as it is a PAIN to try to write this all down.. Feel free to tell me where I lost the plot down in the reply section and I'll clean this tutorial up as needed. Hopefully its enough for people to get started with their planning.
Edit 1: Ok.. the LEDs can be seen with doors off for those under about 5'9". I forgot to crouch. So.. MOSTLY successful. Really depends on how you position them though.
Not messy at all. A very well written guide. Thank you sir.
Bee Bop
Shane
Temple GA
21 Bronco Badlands, 02 Mustang GT Vert, 91 S10
@Theherofails there should be a light on the cross bar above the rear seats. I think you have it turned off.
Ford Bronco Adding interior LED ambient lighting (now with working photos!) 1636159127408
Theherofails
Theherofails
Thomas
Phoenix
Its on, but very dim. I'm going to check it out tonight when it gets dark and see if maybe the bulb/LED is bad. It puts out light, but nowhere near some of these people are getting.
With that said, the LED install is still totally worth it. Not pictured is me driving down the road with a full disco going on in my back seat. The LED lights I used also go CRAZY bright, which is really handy when off-roading/camping.
JaxGtc
Mine is all the way up and it doesn't appear that bright. You have some surrounding light outside the vehicle and I pretty much took it in a dark garage. Hard to tell in the picture but it is not real bright.
Ford Bronco Adding interior LED ambient lighting (now with working photos!) IMG_4159
The actual light is just a little guy:
Ford Bronco Adding interior LED ambient lighting (now with working photos!) IMG_4163
Scohin
Ford Fusion
You think one could replace it with a different color LED?
Theherofails
Theherofails
Thomas
Phoenix
Ford Bronco Adding interior LED ambient lighting (now with working photos!) 20211105_181516
Ford Bronco Adding interior LED ambient lighting (now with working photos!) 20211105_181528
You can see the rear light and ambient light on.. it really is that dark.
Ford Bronco Adding interior LED ambient lighting (now with working photos!) 20211105_182011
This is the same setup with the seats folded. You can see that all the lights are on..
Ford Bronco Adding interior LED ambient lighting (now with working photos!) 20211105_182457
Even with the red I usually have on at night (doesn't hurt night vision), you can actually see your stuff in the back instead of having to bust out my flashlight.
69BroncoX302
1969 U15, 2021 First Edition
interesting, must be a bulb issues, don't say anything, they might hold out more broncos due to bulbs not being bright enough lol
Theherofails
Theherofails
Thomas
Phoenix
Badlands has all black matte interior. It really is a black hole when you tint the top.
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
In these pictures your dome light is not on.
Theherofails
Theherofails
Thomas
Phoenix
If by dome light you mean the small light on the cross pillar, I assure you it is. It's just pointless.
Ford Bronco Adding interior LED ambient lighting (now with working photos!) 20211105_190538
ATLBronco75
Tom
Atlanta GA
2.7 Badlands
Something is wrong. I agree the interior is dark because of all the black but my dome light is blinding!
Theherofails
Theherofails
Thomas
Phoenix
You could be right. I'll put it on the list of weird things about the Bronco.
We have some people saying it's blinding and others saying their interior is cave like. In a sane world, this wouldnt be happening. Chalk it up to being stuck in clown world. 🤡
