Adding fog lamps standard bumper
aktrail
Todd
Alaska
Does anyone know if the fog lamps switch and wiring harness is present on a 2025 Big Bend Mid package?
Thanks,
Fog lights used to be standard on Big Bend trim, not sure for MY25 though.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Not by default. Available with the Black Diamond package.
Denis85
New York
2025 Bronco
i had the same question. what do i need to purchase in order to add them?
other than the bezel that goes into the bumper, ( More Information for VARIOUS MFR FO1039217 ) what else would i need to install factory style fogs? i dont mind a little wiring since im assuming there wont be any factory wiring there. i figure i can just tap into the low beams?
do the factory fogs attach directly to the bezel or somewhere on the frame behind the bezel?
Denis85
New York
2025 Bronco
bumping this thread again. Anyone add fogs to the standard plastic bumper? 2025 Big Bend doesnt have an option for fogs.
RArceneaux
Robert
Youngsville, LA
2025 Ford Bronco Bend
I have the same question. Is there a connection in the forward harness to connect fog lights? Does the lighting switch have the wiring, just not the switch, in place?
would love to know!
GnormalGnome
ee
PNW
2025 Ford Bronco
Thanks,
It's my understanding that for MY25 the harness pigtails are not present on trims that don't come with fog lights. That makes oem retrofitting a little harder but not impossible.
Avoid tapping into the headlight circuit (for this or really any wiring project).
Check this thread for info on where you might be able to tap into the proper circuit:
https://www.bronco6g.com/forum/threads/no-factory-fog-light-pigtails.118981/
You'll still need the headlight switch with fog option, and then you need to enable the fog circuit using forscan. There's multiple threads with those steps and the correct part number for the switch.
