Accessing Rear Light: Stripped Pin/Fastener
bniknar
Bri
An old EcoDriver
Hello,
I've changed my Halogen backup lights to LED - they work great! However along the way I stripped a fastener; I've been trying to find the part# to replace but I haven't been successful so far (I've been using Lakeland Ford Online Parts, which is great, I just don't know how to describe this properly). So: here's a pic of a fastener that wasn't ruined - it's a plastic expanding sleeve with a plastic washer and a black steel philips-head screw:
Ford Bronco Accessing Rear Light: Stripped Pin/Fastener IMG_0691
Here is a pic of where the fastners fit:
Ford Bronco Accessing Rear Light: Stripped Pin/Fastener rearLight
Appreciate any suggestions. Thanks!
orion
Jeremy
17' F-250, 17' Explorer
Hello,
I don't think you need to replace. Half of those around your car are probably "stripped". They're not stripped. As long as the sleeve is intact and screw sits flush, your good to go. Screw is there to spread that sleeve and that is what holds the two pieces together. Now, if you are having issues pulling one out due to screw just spinning, use a trim panel tool to put pressure on sleeve, then unscrew.
dgorsett
colorado
F250, Mustang, Explorer
...or get frustrated, grab with leatherman and rip out... there like four ot them per light, 3 oughta hold
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Sounds like something Ford QC might say… :ROFLMAO:
TXscooterguy
Dennis
Bedford, TX
1969 Corvette Convertible
Ford uses these "pins" in a number of places. Therefore them come in different shaft lengths. Make sure you get the right length for your application.
