Rear brake light replacement bulb
SLBronco11
Buffalo Grove IL
Hi All,
I have non LED taillights and the brake light is out on the drivers side. Is it just a replacement bulb or do I need to change out the whole thing? If it’s just the bulb, can someone please help me out with the part number?
Thanks
RallyGorgo
George
Spencerport, NY
2023 Ford Bronco Badlands
Pages 367-369 in the owners manual (according to the pdf copy I downloaded for my ‘23 Badlands). This is a chart of the bulbs from the manual, has the bulb type listed (WT21W/7W).
Ford Bronco Rear brake light replacement bulb IMG_0247
SLBronco11
SLBronco11
Buffalo Grove IL
Thanks a ton!
Iceman62
Tim
Omaha, NE
2024 Bronco / Sasquatch
@SLBronco11 - this table may not be same for your model. Google "2021 ford bronco big bend replacement light bulbs size" to find your size/options.
You can change the lamp but you have to pull the entire light assembly out to do it
SLBronco11
SLBronco11
Buffalo Grove IL
Lej512
60th Anniversary
Larry
Queensbury, NY
2026 Bronco Outer Banks Sasquatch
60th Anniversary
Hi All,
Thanks
Be glad it's the driver's side. Pulling either tail light housing is a huge pain in the ass but I found the driver's side easier than the passenger's side. I call these newer vehicles "Lego Cars" because they're designed to be snapped together once... at the factory. Be as careful as you can and some plastic still gets broken.
Truth. Passenger side is twice as hard
RallyGorgo
George
Spencerport, NY
OP, what bulb did your Bronco take? I’m curious to see if the owners manual is wrong as someone else suggested.
Ducati1098
It’s not wrong. All models with halogen rear lights are the same.
JL3Z-13466-F is the Ford part number and it matches the owners manual.
HoosierMan
Don
Indiana
2023 BASEQUATCH, 2011 MUSTANG GT, 2014 F350
Yep, I replaced my Halogen's with LED bulbs, and the lower panel on the passenger side broke loose from the mounting bracket. Had to reattach it to the bracket with construction adhesive. Still holding so far!
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Lej512
60th Anniversary
Larry
Queensbury, NY
60th Anniversary
Yep, I replaced my Halogen's with LED bulbs, and I the lower panel on the passenger side broke loose from the mounting bracket. Had to reattach it to the bracket with construction adhesive. Still holding so far!
ME TOO! I used JB Weld. Pissed me off.
