Dimitar
Dimitar
Orange County, CA
21 Bronco
In preparation for the upcoming @EXO Bronco expedition, I decided to install a dual band radio which can work on both GMRS and HAM frequencies. Most of the content out there is focused on GMRS only or compact radios so I figured I'd post this and maybe this will inspire somebody.
The neat thing about this radio is that the controller unit detaches which allowed me to mount the radio above the glove box and disperse the remaining components (controller, speaker, microphone + antenna).
Let me know if you have any questions.
Main Parts:
Radio: ICOM-2730A (50 Watts) + MARS Mod
Antenna: Comet SBB-5NMO 2M/70cm Dual Band
Antenna Cable: Midland NMO Antenna Cable
Antenna Mount: LOD Offroad Spare Tire Mount
Controller Mount: M2M Overhead Basket
Mic Extension: DONG 3 Meter Mic Extension
Speaker: 5W HAM Radio Speaker
Optional:
Center Console Mount: 1" Ball Mounting Plate
NOTE: I don't really love the center console mount. I didn't want to pay $100+ for Archetype Racing's mount so I grabbed some Amazon off brand one and made it work. You don't need it for this set up but I wanted to also have a ball for mounting an iPad in the future. Looks like there's some good options lately, maybe I'll 3D print one.
Total cost was about $650.
The main radio unit is mounted above the glove box. It doesn't interfere with the glove box and it doesn't block the air filter. I mounted it using some basic $3 corner brackets from Home Depot (M2M does make a bracket but it's $50 and I don't think it will actually do the job because the unit is so much bigger).
Pictures:
YT Short: https://www.youtube.com/shorts/E1CqnVO0ucw
Ford Bronco Sleeker Dual Band Radio Install (UHF/VHF) ICOM-2730A IMG_1143
Ford Bronco Sleeker Dual Band Radio Install (UHF/VHF) ICOM-2730A IMG_1145
Ford Bronco Sleeker Dual Band Radio Install (UHF/VHF) ICOM-2730A IMG_1146
Ford Bronco Sleeker Dual Band Radio Install (UHF/VHF) ICOM-2730A IMG_1144
Ford Bronco Sleeker Dual Band Radio Install (UHF/VHF) ICOM-2730A IMG_1147
Ford Bronco Sleeker Dual Band Radio Install (UHF/VHF) ICOM-2730A IMG_1148
Ford Bronco Sleeker Dual Band Radio Install (UHF/VHF) ICOM-2730A IMG_1149
EOSeabee
Patrick
Las Vegas
2022 Ford Bronco 4 Door Badlands
How did you run power to the unit in the roof? I also have that basket.
Dimitar
Dimitar
Dimitar
Orange County, CA
21 Bronco
It’s a single data/power cable from the main unit. I ran it behind the trim in the A-Pillar.
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
Nice setup. I didn’t realize dual band radios are available. That simplifies things. Baja is all HAM. Been many times. Enjoy that EXO trip. That’s a bucket list thing for me.
for the antenna cable I assume you had to remove the interior panels and run that through the tailgate. Is that accurate? I just did that for a compressor.
just gotta figure out where to locate the controller. I have a j-top so can’t use the M2M basket.
just curious why you don’t have a dash rail to mount things to.
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
Looks good! Good use of the Squatch basket...
I mounted my Kenwood TM-V17A to a Lobo overhead mount system. The transceiver and external speaker is mounted at the rear, and the front panel is mounted to the SwitchPros mounting plate. I have it wired to Aux1 using the factory wiring in the roof/kick panel. I'm using a Larsen NMO2/70B dual band antenna on a MTM pod light mount.
Ford Bronco Sleeker Dual Band Radio Install (UHF/VHF) ICOM-2730A 20240826_121439
Ford Bronco Sleeker Dual Band Radio Install (UHF/VHF) ICOM-2730A 20240826_121406
Ford Bronco Sleeker Dual Band Radio Install (UHF/VHF) ICOM-2730A 20240826_122752
CalvinT
Calvin
Phoenix, AZ
Mounting a radio is one reason I"m thinking about getting the Lobo system. How do you like it?
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
I use a TM-v17A on my Colorado ZR2 and love how easy it is to use. On my Bronco I did decide to switch it up a bit and went with a Yaesu FTM - 400XDR
Arokcrwlr
Kraig
US - Alabama
Love it - very clean solution for mounting whatever...
Arokcrwlr
Kraig
US - Alabama
I almost bought a FTM-400XDR, but couldn't justify another mobile rig at the time. How do you like it? The Kenwood is a great radio.
Dimitar
Dimitar
Dimitar
Orange County, CA
21 Bronco
I wanted to keep the dash clean. Can definitely be done with a rail and some attachments.
CalvinT
Calvin
Phoenix, AZ
Which finish did you order for your Lobo rack?
CalvinT
Calvin
Phoenix, AZ
Any
I actually got the raw aluminum and got it powder coated locally.
Any reason why? Their prices for finishing seem very reasonable.
Shrek27
Fullerton CA
Main Parts:
Optional:
Pictures:
This is a great setup! Not a radio guy so was curious...
Was the MARS mod needed for the radio to work for this trip? Or are you just a radio guy? I googled the mod and still don't understand if needed to run HAM and GMRS.
Also is the speaker needed because you put the unit inside the dash? Would you need it if mounted in open cab?
