Fabtech Motorsports
Lux Sponsor (Level 2)
Matt
CA
Bronco, jeeps, trucks
TL/DR
We make a system for the 2 door Bronco
(There are options for Bilstein or non-Bilstein setups)
Link:
4-uniball-uca-lift-kit-front-dirt-logic-2-5-resi-coilovers-rear-dirt-logic-resi-coilovers-k2390dl
Fabtech’s high quality 2-door Bronco lift kit offers increased front suspension travel for enhanced offroad capabilities with clearance to run 35″ tall tires. The stance of the vehicle with this kit will become more level front to rear for an aggressive look.
The factory Bronco upper control arms are replaced with Fabtech’s Uniball Upper Control Arms that provide additional wheel travel with an extra degree of caster compared to stock arms. The increased caster helps to balance steering effort with oversized tires.
The Fabtech upper control arms are constructed of the finest material with .120″ wall 1.25″ OD 4130 Chromoly steel tubing. High quality 1″ FK Stainless PTFE lined Uniball bearings are utilized in place of the small factory ball joints and allow for increased travel without bind. These super stout Bronco upper control arms are designed for longevity in rugged offroad conditions while providing a more positive on road feel.
The Fabtech upper control arms have been designed to work in conjunction with the Dirt Logic 2.5 Coilover shocks to provide additional front wheel travel. The Dirt Logic 2.5 shocks features a stainless steel body for maximum corrosion resistance. These shocks have been extensively ride tuned over thousands of miles in various on and offroad terrain to establish the finest overall ride quality. They will provide a superior ride compared to the factory coilover shocks.
The rear suspension receives Adjustable Lower Link Arms with Fabtech’s lifetime 5 Ton joints®. The lower links are .313 thick wall tubing that are guaranteed never to bend giving you the confidence to crawl over large rocks and obstacles with no issue.
The rear Dirt Logic 2.5 Coilovers feature coil springs designed specifically for the 2-door model. The factory 2-door Bronco uses the same rear shocks as the 4-door model. Using this higher spring rate on the lighter 2-door Bronco results in a harsher ride. To obtain the finest ride quality without losing load carrying capacity, Fabtech designed a 2-door specific spring.
This system is perfect for those that want increased suspension performance with a low lift height. A great choice for daily drivers that want a clean look with the ability to hit the trails on weekends.
BronchoPeat
Pete
Ohio
www.evergreenclothier.com
'18 Tiguan S w/4motion | '14 Fiesta SE Hatchback
My garage door opening is punching the air right now.
timhood
Tim
Several
What is the new ground clearance after installation?
Fabtech Motorsports
Fabtech Motorsports
Matt
CA
About 4" over stock on 35" tires. :)
I am so sorry, saw the dad joke opportunity and took the shot.
Where do you want that measurement from and I can ask if they captured that on the install.
timhood
Tim
Several
I'm not a customer at this point, so don't have anyone go through any trouble on my account. More of a curiosity question that maybe others might have about how much extra clearance they will get on the scrapy parts. :)
Fabtech Motorsports
Fabtech Motorsports
Matt
CA
Fabtech Motorsports
Fabtech Motorsports
Matt
CA
Info is key! I will see what I can gather.
My guys are out scouting trails for some upcoming videos will hopefully get that info the next day o so.
Bronccraig
Craig
Orlando Florida
2009 Challenger RT Hemi Orange
Love the look, have a 2 inch on my poor mans CG BB 2 DR MT but love this height too
Fabtech Motorsports
Fabtech Motorsports
Matt
CA
The 2 doors are growing on me, for sure.
I think they are just a nice package.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
And where can you get your kits "professionally" installed?
With emphasis on that word "professionally", I mean by mechanics who have been to your headquarters for factory training.
The country is amok with shops selling everything, but lacking any manufacturer training and oversight.
Aonarch
Jack Hoff
MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
What about CV angle, are you all not worried about exceeding Ford's recommended maximum angle?
I'd recommend including a diff drop in this package if you are going to run such an extreme lift height.
Fabtech Motorsports
Fabtech Motorsports
Matt
CA
Not a concern from us. If it were we would address it. But a great question!!
Tech has the most up to date info on this.
877-432-2832
Smocaine
DFW, TX
Cervelo Caledonia
The listing footnotes say models with non-Bilstein shocks only - does this kit then exclude all Badlands and Sasquatch (factory Bilstein) models?
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
Everglades
877-432-2832
Then please have "Tech" post a reply to this concern.
It's absurd that FabTech's sales force is unaware of the condition of the dealer body.
