4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
We've got a surprise for you guys. A sneak peak at the new Form Lighting headlights for the 2021+ Ford Bronco! These are being announced at SEMA today but we were able to get our hands on them early to provide some feedback/photos/review.
UPDATE: These are now available for purchase here: https://www.4x4truckleds.com/form-lighting-2021-2024-ford-bronco-led-projector-headlights-pair
They feature a dual-color DRL. That means you don't have to select white or amber DRL when you order them, both colors are built in. It's easy to change colors as well. There is a single wire connector on each side. Plug it in, you've got white DRL. Unplug it, you've got amber DRL. Real simple. No need to remove the headlights to change the color of your DRL.
They also feature quad LED projectors on each side along with a sequential turn signal (the center horizontal bar is sequential). Output is great as well.
We have them available and will start taking orders 11/14/2023.
Sequential LED Headlights from Form Lighting are the perfect way to upgrade your 2021+ Bronco. With these premium OE-grade replacements, you’ll add sequential turn signals, a unique startup sequence, a diffused DRL in white or amber, and a more aggressive, blacked-out appearance.
Increased Light Output. These headlights feature four LED projectors, which provide increased output for both low beam and high beam. The top two projectors function as your low beam, while all four projectors function as your high beam, providing a sharp, strong beam pattern to illuminate the road ahead.
Startup Sequence. These headlights are packed with the latest and most modern lighting functions, including a unique startup or “welcome” sequence. Anytime the running lights turn on, they will illuminate in a sweeping pattern across the entire lamp, gradually increasing in intensity until it fully illuminates.
Sequential Turn Signal. The startup sequence isn’t the only thing that stands out. These headlights also feature an integrated sequential LED turn signal. Every time the turn signal is activated, amber LEDs in the horizontal bar activate in a smooth, chasing sequence. When you’re finished making your turn, they automatically “switch back” to your chosen DRL color.
Selectable DRL. These headlights feature a selectable DRL with a clean diffused optic, that allows you to choose between cool white or amber. Best of all, you can switch colors easily using a simple connector. There is no need to take the headlights off the vehicle!
OEM-Grade Construction. Form Lighting headlights are built with quality in mind, using OE-grade materials and design techniques. This includes durable UV-coated polycarbonate lenses, automotive-grade LED emitters, breather vents, and OEM plug-and-play connectors. They are assembled in an IATF 16949-certified facility, which is a quality management system designed for the automotive industry. While they may not be the cheapest option you’ll find, you can rest assured that these lights will provide durable and superior performance.
Road Legal. Form Lighting headlights meet all SAE, DOT, FMVSS, and CMVSS standards and regulations for legal on-road use in the United States and Canada, when installed and aimed properly - which is easy to do with the integrated screw-type adjusters.
Plug-and-Play. Our headlights for the Bronco are completely plug-and play for for simple installation. They were designed to plug into your factory headlight connector, and they fit perfectly without any gaps. No errors, flickering, or hyperflashing!
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. On the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
What's Included
Quantity: Pair (Left and Right Side)
Fitment
NOTE
: These lamps are compatible with all factory headlamp styles on the Base, Big Bend, Black Diamond, Outer Banks, Bandlands, Wildtrak, Everglades, and Raptor trim levels. These lamps are compatible with USDM models only.
Application: Headlamp
Make: Ford
Model: Bronco
Years: 2021, 2022, 2023, 2024
Ford Bronco New Bronco Headlights from Form Lighting 1 (small)
Ford Bronco New Bronco Headlights from Form Lighting 2 (small)
Ford Bronco New Bronco Headlights from Form Lighting 3 (small)
Ford Bronco New Bronco Headlights from Form Lighting 4 (small)
Ford Bronco New Bronco Headlights from Form Lighting 5 (small)
Ford Bronco New Bronco Headlights from Form Lighting 6 (small)
Ford Bronco New Bronco Headlights from Form Lighting 7 (small)
Ford Bronco New Bronco Headlights from Form Lighting 8 (small)
Ford Bronco New Bronco Headlights from Form Lighting 9 (small)
Ford Bronco New Bronco Headlights from Form Lighting 10 (small)
Ford Bronco New Bronco Headlights from Form Lighting Side by Side (small)
Ford Bronco New Bronco Headlights from Form Lighting 1699565174960
Ford Bronco New Bronco Headlights from Form Lighting 1699565179517
Ford Bronco New Bronco Headlights from Form Lighting 1699565184550
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
jalawson
TX
‘22 Bronco, ‘17 F150
Nice! Seems to be exactly what I’m looking for.
Are the turn signals switch back if it’s on the white setting or does the white turn off?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I believe so because state law requires amber turn signals. I'll try tomorrow when im back at the shop
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
Eager for more details!
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Here ya go. Switchback. If you have Amber DRL selected it's Amber obviously. However if you have white DRL and put the turn signals on, the horizontal turn signal indicator is amber
First 2 clips are Amber DRL
Second 2 clips are White DRL
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
Thanks for info and video. They do look great. Is it possible to set the lights to have white DRL halo rings, but with amber DRL horizontal bars? I’m guessing probably not - it’s either all-white DRL or all-amber DRL, right?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
No I don't see a way to do that. It's either all white DRL or all Amber DRL. But you're not locked in as I said. You just plug or unplug a connector on the back of the light and you can change colors. I did that in a few seconds without removing the headlights from the truck.
Ryslegit
SoCal
22 Bronco Badlands Sas
Look like Alpharex replicas...how do they perform in comparison?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
These look great.
Bronc6g22
Jake
Washington
Mazda 6, Tacoma TRDOR
Any photos of beam pattern / brightness versus OEM led?
