Status
Not open for further replies.
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
AR | BRONCO Modular Roof Rack
*The 4 door design in the renderings below and the 2 door design will lauch at the same time.
I'll get 2 door renders up after Christmas.
This is a project that has been on our development white board since day one. There was always another project that bumped the roof rack down the list, so we had to draw a line in the sand to get the design completed.
We rolled years of various roof rack use on different vehicles and real world practicality into our design. With the feedback provided from the community, our real world experience, what we knew about the Bronco, and our arsenal of sauce, we came up with a roof racked that I'm personally super stoked about. Without taking a 'money is no object' approach, I think we still pulled off a very premium design that is just chock full of details, functionality, flexibility, and a look all its own.
Key design features that had to have a check mark next to them were:
  • Aluminum structure throughout (ZERO steel)
  • Lightweight
  • Low Profile
  • Modularity
  • Easy to accessorize
  • A fresh approach to lashing all of your accoutrements
  • Roof panels are accessible/removable
  • Maximize the area allotted
  • Provide possibilities for further design development
  • Incorporate Carbon Fiber & Carbon Composite
The Roof Top MOLLE Panel (RTMP)
Once we got into the design, we knew we had to have the RTMP. Yes, T-Slot is great for accessory lashing, but you're limited to lateral and longitudinal choices. The RTMP with the red billet aluminum tie lashing anchors makes lashing odd shaped accessories a breeze and makes the use of space ultra efficient.
Billet Mounts... all of them
The use of billet machined mounts at all six locations is really what begins to set this roof rack design apart from all of the other steel black tube powdercoated options that litter the landscape. Just to accentuate our billet parts a little more, they'll be finished in gunmetal grey. Each mount is location specific. This allows a perfect fitment where the mount mates to the body or roof. We take it a step further by cantilevering the mount outboard to add about ~6" more width to what's typical. Visually, the rack looks proper, because the width matches the width of the roof. It doesn't look like it was a recycled Bronco Sport roof rack that was thrown on a full size Bronco. This means your large roof top tents will be fully enveloped by the roof rack. You won't have that Burger King Whopper look, where the meat patty hangs over the bun. To everyone, it will appear like you thought this all out. You're welcome. ;)
The forward mount pair will have provisions to mount our light bar. We call it THE FIRST DAY. Designed for five @Baja Designs LP6s, because who doesn't want 50,000+ Lumen at their fingertips. There is an area to enclose the wiring harnesses, a carbon panel panel to close it off, and mount locations for the carbon fiber AERO-FAIRING to knock the wind dB down. Full carbon fiber construction with V weave. All of these components can be removed and installed, as the mission requires.
Modular Cross Bars
They're essential to the structure. They're configurable, removable, adjustable, and clean. We sourced a strong, low profile, aluminum extrusion for the task. We'll machine our own corner sections to connect the frame out of 6061-T6. The extrusion has two mount grooves with 1" between the grooves. This allows you to mount the cross bars flush with the top of the rail or 1" below the top rail to create a rim around the load space or allow the use of the RTMP and still remain below the rim of the rack. -smart.
As always, there's always more to come. Two door will launch at the same time as the 4 door design. Gotta love the modular design. I'd expect it to be 20-30% lower in cost. I just wanted to get an official thread going for the Roof Rack, now that it's past design and the parts are going into production. As of now, Price is TBD. I'm shooting/hoping for sub $2k on the base rack. The accessories are a' la carte. Not everyone will need THE FIRST DAY. Not everyone will want the Aero-Fairing. You can always order the accessories at a later date. That RTMP, I think, is a game changer. We have another product that will be based solely on the RTMP. I'll get a thread going for that soon!
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501 - LCR-1 Bronco - 1s
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501 - LCR-1 Bronco - 2s
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501 - LCR-1 Bronco - 3s
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501 - LCR-1 Bronco - 4s
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501 - LCR-1 Bronco - 5s
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501 - LCR-1 Bronco - 6
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501 - LCR-1 Bronco - 7
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501 - LCR-1 Bronco - 8
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501 - LCR-1 Bronco - 9
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501 - LCR-1 Bronco - 10
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501 - LCR-1 Bronco - 11
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-1 - LCR-1 Bronco - Bas
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-2 - LCR-1 Bronco - Base and Deflector
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-3 - LCR-1 Bronco - RTMP and Deflector
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-4 - LCR-1 Bronco - RTMP w Tent
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-5 - LCR-1 Bronco - Limb-Riser_RTMP
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-6 - LCR-1 Bronco - First-Day_RTMP
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-7 - LCR-1 Bronco - First-Day_RTMP_Deflector
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-8 - LCR-1 Bronco - First-Day_RTMP_Deflector_Limb-Riser
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-9 - LCR-1 Bronco - First-Day_RTMP_Deflector_Limb-Riser_Tent
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-10 - LCR-1 Bronco - First-Day_RTMP_Deflector_Limb-Riser_Tent
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-11 - LCR-1 Bronco - First-Day_RTMP_Deflector_Limb-Riser
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-12 - LCR-1 Bronco - First-Day_RTMP_Limb-Riser
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-13 - LCR-1 Bronco - RTMP_Limb-Riser
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-14 - LCR-1 Bronco - Base_Deflector
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-15 - LCR-1 Bronco - Base_Deflector_Limb-Riser
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-16 - LCR-1 Bronco - Base_First-Day
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-17 - LCR-1 Bronco - Base_Deflector_First-Day
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-18 - LCR-1 Bronco - Base_Limb-Riser
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-19 - LCR-1 Bronco - Base_Limb-Riser_First-Day
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-20 - LCR-1 Bronco - Base_Deflector_Limb-Riser_First-Day
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-21 - LCR-1 Bronco - Bas
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-22 - LCR-1 Bronco - Base_RTMP
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-23 - LCR-1 Bronco - Base_Deflector_RTMP
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501-24 - LCR-1 Bronco - Base_Deflector_RTMP_First-Day
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501_Pinaccle_A-F - Bronco
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501_Pinaccle_A-F_RTMP - Bronco
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501_Pinaccle_Base - Bronco 2
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501_Pinaccle_RTMP - Bronco
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501_Pinaccle_RTMP - Detail 1
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501_Pinaccle_RTMP - Detail 2
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501_Pinaccle_RTMP - Detail 3
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501_RTMP_8020_Mount
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door 2501_RTMP_Molle_Loo
Gabby
Gabriella
Milwaukee
22' Bronco, 16 Tiger 800XCx, 96 Duc 900SS/Sp
What's the...
Total weight of the base product?
Static & Dynamic Load?
Dimensions?
Total Height?
Plan to protect that carbon peice (if it's real carbon) from UV damage?
Gritty
Stan
Oak Island, NC 28465
2019 Chevy Colorado ZR2
  • Lightweight
  • Low Profile
  • Modularity
Modular Cross Bars
As always, there's always more to come. I just wanted to get an official thread going for the Roof Rack, now that it's past design and the parts are going into production. As of now, Price is TBD. I'm shooting/hoping for sub $2k on the base rack. The accessories are a' la carte. Not everyone will need THE FIRST DAY. Not everyone will want the Aero-Fairing. You can always order the accessories at a later date. That RTMP, I think, is a game changer. We have another product that will be based solely on the RTMP. I'll get a thread going for that soon!
Okay, I'll be the first.......2dr availability?
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
Yup. Two door will launch at the same time as the 4 door. I'll add that to post 1.
Umichigan1
2022 2-Door Bronco
Why is billet material necessary? The roof rack strength and durability should be limited to the capabilities of the roof structure. Using bullet manufacturing processes (which adds expense dramatically) seems over the top. Cast materials would seem to be more efficient and economical unless the business plan is intentionally skewed towards low volume and high piece price.
AK SNO RIDER
Ty
Alaska
I'm gonna assume you've never taken a scroll through Archetypes website. Thats just how they roll. This is a company who machines side steps out of 12 foot long billets. They sell $4,000 wings for Shelbys. They build stuff to their liking and not to a price point.
And why not? Tons of other companies building things how you're asking, nice to have one who overbuilds the shit out of things just because.
AK SNO RIDER
Ty
Alaska
Imma be honest @EIGHTLUG, as incredible as I'm sure this rack will be, I'm bummed to see it looks like it is several inches wider than I want. Looks wider than the roof itself, and purely from an aesthetics point of view, I like the narrower racks that more closely match the taper of the roof.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
  • Lightweight
  • Low Profile
  • Modularity
Modular Cross Bars
Looks great!
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
Not so fast, my friend. 😉 We already have the rear mounts designed for the narrow rack. The only design change still necessary is the narrower RTMP. I’m telling you, this Modular design is an amazing piece of kit. And not just for Bronco 2 door and 4 door. The design can be adapted to other vehicles.
Below is one of the earlier renders of the roof rack. Here you can see the total width, in relation to the roofline and sides of the Bronco.
Ford Bronco AR | BRONCO Modular Roof Rack for 2-Door and 4-Door FC5F58D5-F9C7-4988-B819-1EE963145143
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Looking forward to see how this progresses. As always, stunned by the level of detail and design standards.
I want to see the wide base over the soft top. It might actually look great. Can't wait to see that version. It may offset my search for a hardtop in 2023 - especially if the shorter base will be usable on both...easy of removal of the base is imperative.
I am kinda with @AK SNO RIDER - in that I think the outside edge of the rack should meet the start of the curve of the hardtop - but, I could be proven wrong once we start seeing more.
AK SNO RIDER
Ty
Alaska
So you just went and thought of everything, huh? Haha. Can't wait to see the finished product.
Umichigan1
2022 2-Door Bronco
I get what he is saying. Although technically the rack may fall within the theoretical intersection of the side and top of the roof, it looks larger and oversized. It is an aesthetic opinion, yes, but valid. It "feels" like the rack is too wide.
Umichigan1
2022 2-Door Bronco
Sometimes engineers/designers fall in love with their own product and lose objectivity.
redone17
Cold Spring, NY
@EIGHTLUG - what’s the width of the full size base? I’m looking at mounting a 50” Superlite on an as needed basis with quick release mounts.
Status
