Nflandrum
Ned
Northern virginia
2009 Dodge Challenger
It looks like to remove the rear portion of the hard top I could leave the mounts attached to the windshield and rear hardtop and instead just detach the superstructure from the mounts themselves. Is that accurate?
TX21BRONC
Bill
Allen, TX
Jeep Grand Cherokee Summit Hemi, Range Rover Sport
I have purchased and have been extremely satisfied with many of your products that I have purchased from you. I am sure this roof rack will be another engineering masterpiece. But...You need to get a soft top version designed right away. There are so many roof racks available right now for the hard tops and only a couple for the soft top. And the majority of Broncos on the road right now are soft top. Not sure why everyone goes right for a hard top rack design. I mean, how hard can it be to perfect a soft top roof rack. The concept of properly mounting it is out there, we just need someone to do it correctly. The minimum requirement for a soft top would be that you can mount and support a roof top tent and allow the rear to open up. Look at JCR's.
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
@EIGHTLUG JCR is good in that it's one of the only soft top racks that let's you still pop the clamshell. Raket is better with how quickly you can remove the rack to flip back your soft top. It's just hard to stomach nearly $3K.
JohnnyBronco
Pennsylania
X4
Why is billet material necessary? The roof rack strength and durability should be limited to the capabilities of the roof structure. Using bullet manufacturing processes (which adds expense dramatically) seems over the top. Cast materials would seem to be more efficient and economical unless the business plan is intentionally skewed towards low volume and high piece price.
Did you never watch a video of how Apple mKes your MacBook housing from a solid block? Some things lose strength if cast or molded
And maybe they don't have a forge on site to liquefy aluminum or steel to cast the items
Gritty
Stan
Oak Island, NC 28465
2019 Chevy Colorado ZR2
The first what?? Person to not read the actual post? 2 and 4 available
The original post yesterday only show 4dr, it was edited after I replied about the 2dr. See the asterisk*........You have nothing better to do?
telenerd
Laramie
Subaru
Iā€™m 6ft 3. Just my 2 cents, I donā€™t see how I could have a rack on my Bronco without some type of ladder. I was thinking about getting a rack with a ski roof rack on top but after getting my Bronco it be such a hassle due to height. So now I just use a ski bag and store in Bronco. Problem solved and saved quite a bit of money. šŸ˜€
BuckYeah
Seattle
N/A
I love the attention to detail AR pays everything they bring to market. And no, I'm not a paid spokesperson, but I have spoken with a principal at AR and I'm confident the company wants to add value to the Bronco.
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
Correct. I think 12, 1/4" bolts is all it takes. Toss a hex drive on an electric ratchet and you can probably have the rack off in a matter of minutes. The rack is supported from underneath, so as you remove the mount bolts, it wont come crashing down. So pull the bolts and have a buddy help you lift it off or get one of those fancy ceiling mounted garage hoists and done deal. If equipped, the AERO-FAIRING can remain attached to calm the wind down on those roof off days. The lights would also remain installed and operational. It's a total win.
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
Oh, don't you worry. 2 door and 4 door soft top designs are already on the design table. We started with the hard top, because that's what we own. The rack itself will carry over to the soft top, but the soft top will get mount designs specific to that application.
HeHateMe
San Antonio, TX
2020 Hyundai Palisade
Because hardtops, like 4 doors, are *THE BEST*
Of course... You've got to look past all the issues of said hard tops...
Shark1247
Kelly P
Snohomish, WA
23' Badlands Sas Lux
Still haven't seen anything on load weight. Static and dynamic.
jh3113
Jake
Phoenix
Subaru Outback
Easy buy if it looks as good in person as the renders make it look.
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
Iā€™m betting that it will look tremendously good in person. From afar, it will look similar to most, but once you get up close to our rack or are one of those that purchases it and unboxes the bespoke components, youā€™ll quickly find that itā€™s very premium when you hold the precision machined billet components. I say this often about our products, but Iā€™m super stoked for this one. I have a feeling that it will be a game changer.
