6.75 sub for stock sub replacement? B&O
EOD98
Las Vegas
2025 Bronco Badlands Sasquatch
Anyone ever tried a 6.75 sub in the stock enclosure or is it too small? Just curious.
like this one: KICKER 48CWRT674 CompRT 6.75" Subwoofer, DVC, 4-ohm
https://a.co/d/0aJ26B6U
It works. It is an upgrade over stock non-B&O, especially if amped.
If you are going to the trouble though, the 8" also fits with just a minor bit of trimming, and really shines when you put an aftermarket amp and seal the port.
EOD98
Las Vegas
Thanks!
23OBX2.7
AB Canada
2023 Bronco
Defenatley need amp that handles high level signal....Midas well get a good one 400W+ so can upgrade if 8" not good enough or when want more to a tailgate 12" loaded enclosure.
Cordycord
Cord
SoCal
2016 Pilot, 2016 E300, 2005 MSM, 2001 B3500, 2010 Range Rover Sport, 2022 Pilot
I've got a 2025 Heritage with the 7 speaker setup, and apparently the sub amp is more powerful. That probably means 150W instead of 110W.
If I use the stock location and stock amp is 6.75" or 8" recommended? I don't mind trimming. Also, it looks like the OEM subwoofer is 2ohm, wired like below.
Do I go 2 ohm for the 6.75" or the 8"?
Thanks in advance.
Ford Bronco 6.75 sub for stock sub replacement? B&O Single Woofer Setu
