RCI Offroad
RCI Offroad
Loveland Colorado
2021 Bronco 4Dr. 1st Edition, 2022 Badlands 4Dr.
Hi guys, as you may know we just launched our Bronco Rock Sliders and they will start rolling off the line by the end of this week!
Why are they the best sliders available?
-Completely frame mounted design, transfers no load to the vulnerable rocker panels
-Large, flanged frame mounting plates provide unequalled strength and lifting capacity, plus they protect the bottom of the frame from damage
-Every component in the slider including the tube is laser cut and tabbed together for a perfect fit every time
-Standard DOM round tubing and 2" square is far stronger than the usual 1.75" HREW used by others.
-Usable as a step when paired with our dimpled tread plates
-Dual stage epoxy primer and textured black powder coat is done on our own OEM quality automated paint line
-Unbeatable value for the price
5Deg W/ Tread
Ford Bronco RCI Bronco Rock Sliders Are Here! IMG_4430
5Deg W/ Tread
20Deg W/ Tread
5Deg no Tread
Ford Bronco RCI Bronco Rock Sliders Are Here! Bronco Slider No Tread (2)
5Deg W/ Tread
Ford Bronco RCI Bronco Rock Sliders Are Here! Bronco Slider Tread Plate (1)
5Deg no Tread
Ford Bronco RCI Bronco Rock Sliders Are Here! Bronco Slider No Tread (3)
Tread stickout looking straing down from door
Ford Bronco RCI Bronco Rock Sliders Are Here! Bronco Slider Tread Plate (4)
Pinch Seam Guards (Look great and add protection w/ or w/out sliders)
Ford Bronco RCI Bronco Rock Sliders Are Here! 21+ Bronco Pinch Weld Trim (5)
20Deg
Ford Bronco RCI Bronco Rock Sliders Are Here! 21+ Bronco Roof Rack (7)
20Deg
Ford Bronco RCI Bronco Rock Sliders Are Here! 21+ Bronco Roof Rack (8)
20Deg No Tread
20Deg No Tread
20Deg No Tread
Ford Bronco RCI Bronco Rock Sliders Are Here! IMG_4416
20deg No Tread
20Deg No Tread
Ford Bronco RCI Bronco Rock Sliders Are Here! IMG_2109
Slyder
Washington
2014 KTM 1290R
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Where is it made? US Steel? What wall thickness? Is that 2” OD pipe?
RCI Offroad
RCI Offroad
RCI Offroad
Loveland Colorado
Our manufacturing is all done in Loveland, Colorado.
All steel, aluminum, tube, etc is domestic. DOM tube is 1.75" x .120 square tube is 2x2 x .120
RCI Offroad
RCI Offroad
RCI Offroad
Loveland Colorado
2-door too? Or only for 4D?
We have already done a 3d scan on the 2dr and it is in design currently. Hope to launch those within the next 1-2 months.
Saw4Fire
Nederland, CO
1994 Bronco
Badlands77
Minnesota
2012 Ford Focus, 2022 Bronco Badlands
The second to last picture shows a 2-door version, without a tread plate.
They look like they are all on the same vehicle to me… 4 door
cgv
Apex, NC
Bronco Badsquatch, Explorer ST
I assume those pictures are of the 5 degree sliders? Do you have any photos showing the 20 degree sliders?
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Got pictures of how these mount to the frame? Looks like your using gas tank support bolts and the factory front bolt holes that some aftermarket skids use. How much do the deflect with a full weight of the vehicle on them?
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Yaaaas. Finally some proper built sliders.
IMPO, these are the best we’ve seen yet. Well done @RCI Offroad , I look forward to purchasing a set of these if my 2door ever materializes.
Saw4Fire
Nederland, CO
1994 Bronco
kodiakisland
Arkansas
I would also like to see the 20 degree sliders please.
