- Dusty
- Oct 4, 2021
- 18
- 404
- 1,329
- Riverside, CA
- 2021 Bronco Base 2-Door
- Base
EXP Series shock absorbers by ICON Vehicle Dynamics combine the performance of a fully rebuildable 2.5-inch diameter premium shock with the convenience and cost-benefits of re-using the Bronco’s factory coil spring and other components.
EXP bridges the gap between spacer lifts and threaded coilovers, providing suspension lift and custom-tuned suspension performance all in an economical package.
EXP Series is based on ICON’s proven 2.5-inch diameter Aluminum Series shock absorber, featuring a one-piece impact-extruded aluminum shock body. Hard anodizing provides a great-looking, consistent finish with superior resistance to abrasion and corrosion. The massive 7/8-inch diameter shaft is induction hardened and chrome plated. The one-piece digressive piston design is valved specifically for the Bronco to provide unsurpassed performance and ride quality on and off-road.
The 6061 billet aluminum coil spring seat is CNC machined to fit the molded heavy duty urethane coil spring seat that is specifically design for fit each of the Bronco model’s OE coil spring. A series of snap-ring grooves machined into the shock body provide easily-selectable ride height adjustment from 0 to 3” over stock, depending on the Bronco’s OE suspension system (HOSS 1.0 or 2.0). EXP shocks use the factory shaft-up orientation, with the shaft ends machined to re-use the Bronco’s OE upper shock and spring mounts.
EXP shocks are custom tuned by ICON engineers to maximize damping performance when used in conjunction with the Bronco’s stock coil springs. The increased piston size and shock oil volume provided by the 2.5-inch diameter aluminum body provide superior heat dissipation compared to the smaller, steel bodied OE shocks, resulting in longer-lasting shock performance over prolonged use at higher speeds and through rougher terrain. For those who would like to further tune their suspension, EXP shocks are fully re-valvable (and rebuildable) by any qualified shock technician, with parts available from ICON.
FEATURES & BENEFITS
Lift Height Charts for the various snap ring grooves:
FEATURES & BENEFITS
- Vehicle specific design for 2021-UP Ford Bronco with HOSS 1.0 or HOSS 2.0 Suspension Package
- Vehicle specific tuned for superior shock damping and control
- 2.5 Aluminum Series Shock with Internal Reservoir
- HOSS 1.0 version: Adjustable ride height from 1-3/8" to 2-1/2"” of lift over stock (front) with the use of snap ring
- HOSS 2.0 version: Adjustable ride height from 0-2” of lift over stock (front) with the use of snap ring
- Utilizes factory coil and coil hardware
- Inverted shaft up design featuring 7/8” diameter, induction hardened, chrome plated shaft
- One-piece, impact extruded, hard anodized aluminum cylinder offers excellent corrosion resistance and consistent finish
- CNC machined 6061 aluminum components with a black anodized finish
- PTFE lined spherical bearing for extended longevity and minimal deflection
- 100% Bolt-on, no cutting or welding necessary for installation
- Fully rebuildable and re-tunable
- Sold by EACH
| PART NUM | DESCRIPTION | MSRP | WEIGHT |
| 48601 | 21-UP BRONCO HOSS 1.0 PKG 2.5 FRONT EXP COILOVER | 524.95 | 13 |
| 48611 | 21-UP BRONCO HOSS 1.0 PKG 2.5 REAR EXP COILOVER | 524.95 | 13 |
| 48602 | 21-UP BRONCO HOSS 2.0 PKG 2.5 FRONT EXP COILOVER | 524.95 | 13 |
| 48612 | 21-UP BRONCO HOSS 2.0 PKG 2.5 REAR EXP COILOVER | 524.95 | 13 |
