35s on optional Badlands rims?
ARock0ne
Aaron
Maryland
2021 Bronco Badlands
Hey folks.
I'm expecting my Badlands in a week or two and stoked as hell. I ordered the optional rims instead of stock and, honestly, have wished I'd gone Sas since I got my VIN.
While I love the look of the rims, I would like to add 35s instead of 33s. I am fairly good with the lift I want, so all good there.
I am learning, but still don't know sh!t about however, what size tires work with what rims.
My question to the group is: what 35s will fit on the 17 x 8 rims? Do I need to upgrade to 17 x 8.5 like the Sas to run 35s safely, or go completely after market? If possible, I'd like to keep the stock rims I'm paying $995 for!
Thanks!
A
cpmartin1999
chris
Atlanta
2022 Badlands, 2020 VW Atlas
Hey folks.
Thanks!
A
ive learned its the "offset" on the rims youll need or spacers as mentioned, the wider tires will rub on the inside
grayshadow
Charles
Humble, Texas
You won’t have any issues. This is a friend‘s Badlands that he just put 35’s on with no lift and crash bars are still installed.
Ford Bronco 35s on optional Badlands rims? F57A75A2-F91A-4E1C-A90A-2C6418B67A22
Tdifonzo
Thomas
Audi S3
ARock0ne
ARock0ne
Aaron
Maryland
@grayshadow Freaking cool. Can you please tell me what tires he used?
STX Bronco
South Texas
F150 SuperCrew 22 Badlands
Local dealer put 35’s on their demo and added. 2” lift.
Ford Bronco 35s on optional Badlands rims? 2C6AEACC-B0C4-436A-A47B-D87AB2C412BE
Ford Bronco 35s on optional Badlands rims? 0ECAE6BE-95BA-4D31-8C1B-9B0EA4E2284F
RhodeIslandRed
Northeast
www.bronco6g.com
TD5 Defenders
35 just describes the height of the tire (or the diameter). There are all kinds of sized tires that are 35". For instance, I am running 35x13.5/17s that require a minimum of 9.5" wide rims. The tire dimensions will dictate what the minimum rim width can be. All manufacturers publish this.
But the bigger question you have is offset. The Sas wheels are +30 offset. The stock badlands wheels are +55. Because the tires on the sas are bigger (both wider and taller), they are moving the wheels further out away from the running gear.
You need to read up a lot in the wheels and tire threads. All the answers are there.
here's a good starter https://www.bronco6g.com/forum/threads/stock-wheel-sizes.8137/
here's another good one. https://www.bronco6g.com/forum/threads/wheel-offset-and-backspace-how-do-they-relate.9910/
This one has images of the stamps inside the stock wheels: https://www.bronco6g.com/forum/thre...es-offsets-bolt-pattern-center-bore-⚙️.11893/
If you post the exact tires you want to get (manufacturer, model and size), I'll reply with the minimum wheel width and offset required to probably have no rubbing.
ARock0ne
ARock0ne
Aaron
Maryland
This one has images of the stamps inside the stock wheels: https://www.bronco6g.com/forum/threads/⚙-2021-bronco-oem-factory-rims-wheels-specs-sizes-offsets-bolt-pattern-center-bore-⚙.11893/
Thanks bro. I'll study up.
grayshadow
Charles
Humble, Texas
TyGuy40
Ty
Austin,TX
Triumph Bonneville
Hey folks.
Thanks!
A
I’m in the same boat as you, And was curious if you did any changes yet? Here is my BL:
Ford Bronco 35s on optional Badlands rims? 529AC9E8-65A0-4AFF-A8B6-2BA846A96CDB
ARock0ne
ARock0ne
Aaron
Maryland
Hey there... actually had mine for about two weeks and love the look and handling as is. I also really like having crash bars for peace of mind. I may move up to 35s* with a lift at some point, but for now loving life.
Ford Bronco 35s on optional Badlands rims? 20220106_104232_01
TyGuy40
Ty
Austin,TX
Triumph Bonneville
Totally get it!
those rims really are the best looking wheels in my opinion! I’m fine keeping mine as is for now, as well. Great looking rig!!
American Sender
Here
1970 F250 Highboy, 1969 Bronco and 1968 Mustang
Hey folks.
Thanks!
A
Did you ever make the swap to 35's? I plan on swapping the sasquatch wheels for a set of the Badlands optional wheels when the Goodyears wear out. I think I will try 35x11.5x17 tires.
