2dr backseat delete and utility compartment build
Jfman
jean
Canada
Accord
In this thread I will document my “utility” bronco build.
1st step was to remove the backseats.(no photos, other threads explain this process)
2nd step was to mount thick carpeting to the the side to protect the plastics in preparation for the build. I also hope the carpeting is dampen some of the sounds that may come
from all my junk that will be stored in the back there. Aluminum flat stock to hold the carpet down using the roof mounting bolts.
Ford Bronco 2dr backseat delete and utility compartment build BD844553-EAF3-40F8-984C-6B27EFAFEDEA
Ford Bronco 2dr backseat delete and utility compartment build CFFE17D6-8FB0-4249-8298-95BE9805BF02
tock13
Tony
WA State
Mazda, 66 Honda CT90, ‘94 Toyota Xtra cab
Jfman
jean
Canada
Accord
Then a floor was built with the sides that had to be notched to fit around the bulge in the plastics in the rear of the Bronco.
Ford Bronco 2dr backseat delete and utility compartment build 780AD4D9-F20F-4A84-82F7-5E056A36A35B
Ford Bronco 2dr backseat delete and utility compartment build BB0F4788-66A5-40FB-AA15-8B33AC4641C3
Jfman
jean
Canada
Accord
To go around the bulge, the plywood was doubled up in the inside so it could reach rearward correctly.
Ford Bronco 2dr backseat delete and utility compartment build 2DFDDEEB-385D-4A49-8561-79B92A07A856
Ford Bronco 2dr backseat delete and utility compartment build F709AC19-87CA-4670-AD8D-2ED2D2BC6F73
Jfman
jean
Canada
Accord
The front of the sides are built to allow the seat to fully recline because I may take a nap here and there.
Ford Bronco 2dr backseat delete and utility compartment build A2BD4187-5F46-4D5F-ABE1-7E250616E7A8
BroncoAZ
Mitch
This looks interesting, but also heavy.
Jfman
jean
Canada
Accord
A piano hinge door on the floor so that the underfloor compartment stays accessible. The thick carpeting was also slit to allow lift.
Ford Bronco 2dr backseat delete and utility compartment build 869D6EAD-63AF-406A-BF5C-8E20462FF50F
Ford Bronco 2dr backseat delete and utility compartment build C4B92840-479F-48CF-AAFC-70A3DFDD34DC
Ford Bronco 2dr backseat delete and utility compartment build FE49875A-8E54-4440-8180-C00ABF6AED79
Ford Bronco 2dr backseat delete and utility compartment build 09CC9F98-81B8-451A-81A4-2907B522C8CD
Jfman
jean
Canada
Accord
The front of the compartment is closed in.
Ford Bronco 2dr backseat delete and utility compartment build EA0F45D1-0E9A-411A-B0D6-26FFBEC58E4C
Ford Bronco 2dr backseat delete and utility compartment build B6710B35-6826-40BD-8BC9-FAC1E0B92B7C
KABQ
Aaron
Albuquerque, NM
Can't wait to see it finished!
Desert_Brush
SoCal
2015 Mini Cooper
Jfman
jean
Canada
Accord
Nice! I needed to build something with a top because I carry car parts and expensive tools all the time. I want them to be out of sight (I live in the city and I street park)
