- Bradley
- Jul 19, 2020
- 36
- 823
- 1,561
- Hattiesburg MS
- 18 Sequoia TRD sport, 2021 Badlands Sas, 93 Cobra
- Badlands
Many may or may not know so thought I would tell a little trick.
With the Bronco and F150 (Maybe others also) if the truck is running or off if you push the 7-8 9-0 at the same time it will lock your ride. I use the to walk in stores or when I get out to lock the doors. Personally I never take the keys out of my ride. I just use the keypad.
On the F150 if after you unlock your truck you push the 5-6 it will open the tailgate if it is a power tailgate.
I have never had the problem of the back door not opening on my Bronco without me having the key also but I have never used the key only the pad.
This is said but when I tested I didn't get this result so test before you trust this.
Changing the code and more.
