2026 Ford Bronco Hybrid Teaser
Min_Ahn
Min
Denver, CO
2019 Ford Mustang, 2023 Ford Bronco
Ford Bronco 2026 Ford Bronco Hybrid Teaser 11
Ford has just released a new teaser for an upcoming hybrid version of the Bronco lineup, but it's unclear whether the vehicle shown is the full-size Bronco or the more compact Bronco Sport.
At first glance, the vehicle appears to have side mirrors identical to those on the Bronco Sport, hinting that it might be the smaller model. However, the hood design looks more sculpted and aggressive, aligning more with the full-size Bronco. The front end also seems slightly more angular, and the headlights are now almost square, diverging from the classic circular LEDs seen on current models.
Another detail adding to the mystery is a visible hump between the front seats. This could suggest the presence of a rear-mounted spare tire, a feature found on the full-size Bronco but not on the Bronco Sport.
The Bronco Sport has already received updates for the 2025 model year, including a refreshed design, which makes it unlikely to get another redesign for 2026. Meanwhile, speculation about a hybrid Bronco has been circulating for some time.
If this is indeed a hybrid version of the Bronco Sport, it could likely use the same hybrid powertrain found in the Ford Maverick, as the two models share a similar platform.
For the larger Bronco, a plug-in hybrid variant might adopt the powertrain currently used in the international Ford Ranger PHEV. That setup combines a 2.3-liter turbocharged engine with an electric motor and delivers around 30 miles of electric-only range. This would give it a competitive edge over the Jeep Wrangler 4xe.
At this stage, it appears increasingly likely that the full-size Bronco will be the model to receive a hybrid powertrain, at least in the Chinese market. The smaller mirrors seen in the teaser could simply be part of a broader mid-cycle refresh.
Ducati1098
It’s a Bronco sport. There’s another thread on it floating around.
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
adam1991
VW GTI (2)
A hybrid Bronco may herald the coming of the apocalypse.
Ford will forge the way with all new recalls, such as "the hybrid wiring is too thin" and "we need to stress test it to see if it will fail and need replaced".
56F100
john
Venice, FL
56 Ford F100 with 30K original miles
Awesome! That should save the planet:teehee:
JustinsCustoms
Justin
Wayne Michigan
2024 Ford Bronco Raptor, 2017 Chevy Malibu
I tell you what, the only way to know for sure is to give it about a month or so when the test vehicles get built. My guess is that it is indeed modeled from the Sport because July shutdown wasn't nearly long enough to retool for such major power train changes. If I see it go through and I remember I'll make a thread here.
Dral97
Ford Bronco, Wrangler YJ, LJ, and 392, BMW 4 series
I'm not familiar with hybrids all that much, but I do know the jeep 4xe gets a good torque boost when using the electrical system. I wonder if there is a place for that here on a Bronco in the off road setting.
