2025 Badlands order questions
KC2LLW
Steven
New York
Hello,
I am about to order a 2025 4dr Badlands 2.7 Lux and leather trim package blackout package non Sasquatch. My first question is on the Axles is the 4.46 ratio the same axle size in mm as the 4.7 Sasquatch or are they physically small 190mm vs 210mm? I assume it will still have front and rear lockers? My second question is on the modular bumper this option says it will delete the raptor style running boards and fog lights does this mean there will be no switch on the headlight for the fog lights and no pre wiring? Third question is why the raptor running boards have anything to do with the modular bumper. I was quoted $65,248 for the truck before taxes dose that sound right?
Thanks
MNBigfoot
MN
Axles are the same, front and rear lockers (same as Sas), you lose the fog light switch (I believe it should be pre-wired given the lux package).
No electric seats with a two-door leather package (just and FYI, some people didn't know until they received theirs).
crenca
Southern New Mexico
Yes, Badland trim comes with front & rear lockers + sway bar disconnect
Maybe just yet another quirk of Ford ordering/manufacturing when sometimes seemingly (or actually) unrelated accessories are tied together??
Sounds about right. You could pick up a 24 on the lot today very similarly optioned with the same MSRP, but discounted $5-7k (occasionally even more) in the big cities near me, just an FYI
TJP249
Tom
Davidsonville, Maryland
2000 F350 SD 7.3 PSD, 2023 F350 SD 6.7 PSD, 2014 Ford Explorer PIU
My theory on the front modular bumper or raptor running boards is they attempt to meet a minimum payload number from the factory. They are both heavy options so if you added both of them the payload would dip below a threshold they don’t want to go below. Once again my theory only.
V1Rotate
Bryan
Brevard, NC
2022 Wildtrak
Thanks
I seem to remember in the past this having to do with having to achieve very specific Weights/payload etc. Certain combinations of accessories won't work together on their end but work together perfectly fine in reality
