2023 Outerbanks Brake Failure
MakahaDan
Dan
Makaha, Hawaii
23 Ford Bronco
After waiting 2 years and 3 months. I finally got my Bronco from Windward Ford in Oahu, Hawaii. Drove it for 1,700 miles and brake pedal went to the floor and I had to take evasive action to stop my truck (e-brake). Symptoms- Flashing red brake light, ABS light, two different aural warnings at the same time, Hill start assist warning, antilock brake fault, and precollision assist not available. I shut it down and started it back up. No joy. Called the dealership twice and emailed with no response. I went on the forums and one likely issue was a loose wheel speed sensor. I found a wheel speed sensor that I could get 3/4 of a turn on. Brakes worked for another 25 miles and went out again. This time if I pushed the pedal with both feet, I could get it to stop, but the brakes would lock up no matter what speed. Brought it to the dealership and they said they would fast track it and let me know. The service dept employee told me no loaners were available and the guy that approves rental cars is sick that day. I got a ride home and they called saying its a power brake booster, they will get one in around five days and will let me know an update on Friday. Its Friday. No word. I called. No answer. Happy Easter M.F. (my friend).
Lowcountry Bronco
William
South Carolina Lowcountry
Sorry to hear and yes, aloha Friday is a real thing! Hopefully they'll get you up and running next week.
mirabf
Frank
Tampa
2023 Ford Bronco badlands
I am having the same issue with my 2023 Badlands 1668 miles. Ford replaced the Brake booster and upgraded the firmware. Brakes failed again 100 yards from the dealer! They have it back again and I have to open a ticket with Ford Motors.
dgorsett
colorado
F250, Mustang, Explorer
I hope you guys get this worked out. For the rest of us, which engine?, as each has a different brake booster system.
MakahaDan
MakahaDan
Dan
Makaha, Hawaii
23 Ford Bronco
2.7L in mine. No issues the last two weeks since changing out the brake booster.
KABQ
Aaron
Albuquerque, NM
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
FWIW, most of the brake problems reported are with the electronic brake booster that is only on the 2.7L. Those that have had problems with the 2.3L vacuum brake booster just don't know how to drive with vacuum brake assist brakes. Many are used to just pressing the pedal a single time. But with the VBB, a tap and pump of the brakes and they are very responsive if not too touchy. There have been some legitimate issues with the VBB, but they are resolved with bleeding the line.
mirabf
Frank
Tampa
I have the 2.7
