2022 2.7L Wildtrak Sas ABS malfunction + multiple errors
ram50
Earth
Ford Bronco
My Wildtrak arrived two days ago. About 120 miles later, I got multiple faults (ABS, Pre-Collision Assist Not Available, Drive mode not available, Trail control fault see manual, ESC service required, Park pilot malfunction), so I could no longer change GOAT modes or use ACC/LKA.
I have a service appointment in 9 days, but has this ever happened to anyone else?
Ford Bronco 2022 2.7L Wildtrak Sas ABS malfunction + multiple errors IMG_6384
rb1961
robert
ohio
f150
nope, nothing like that. hope nothing serious.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Does sound familiar. Probably worth checking the connectors for each wheel speed sensor while you wait. Also, @flip can probably look at your codes if you send him your VIN.
KABQ
Aaron
Albuquerque, NM
ram50
ram50
Earth
Ford Bronco
Ducati1098
Fixed one today with a similar issue. Corrosion on the left rear wheel speed sensor connector.
Hopefully it's something easy for you also and your dealership can get it fixed quickly.
ram50
ram50
Earth
Ford Bronco
Update: problem fixed after returning from dealership. They simply reset ABS after finding no mechanical or wiring issues.
TaylorfromTexas
Whitney
2022 bronco
So glad I’m not the only one. Had her 7 days and it’s constant now, everytime I go around a curve it up/down a hill.
UpNover
North Texas
2017 Jeep Wrangler Unlimited Rubicon
Mine done this today , said rear rh speed sensor fault. I pulled the rear sensor and found a few small metal shavings stuck to magnet , I cleaned the sensor and reinstalled, drove about 1/2 mile and codes cleared . Simple task with a 1/4 drive ratchet and 8mm socket, took less than 5 min .
