2 door with RTT?
DeltaBravo
Delta
MIKES MOM
  • Thread starter
  • Banned
  • #1
I know it’s an option with the 2 door in the Ford site but as anyone seen a bronco with a 2 door and rtt?
DC9atnight
Toyota Tacoma
I am hoping this fits given it’s one of the few RTTs that is not overweight for the roof rails but the length might be too long for 2dr.
Ford Bronco 2 door with RTT? 4499D587-49DA-4FC9-A97D-63BF898CF79A
carrellslake
Oregon
2022 Ford Bronco
I made a rough mock-up a while back for my own reference with the GFC Superlite. I believe the length to be accurate.
Ford Bronco 2 door with RTT? gfc superlit
DaveH
14 Ford Focus, 98 Ford Expedition
Just pitch a tent on the ground and embrace the suck.
I was all in for a RTT, but then I started thinking about the Bronco weight limitations. Did I want to devote 160 lbs to a tent? Plus that weight would be in the worst possible location (at the top of the vehicle) for offroad stability.
Next, I settled on the GFC Ultralight which is 80 lbs. Now you've completely lost the use of the rack for anything other than the tent and are still giving up 80 lbs, and you can only sleep 2 people.
Now I'm leaning toward a Gazelle ground tent. Much more economical, they set up really fast, and weigh about 30 lbs. And you don't have to have a hardtop on to use it.
I might feel differently about a ground tent if I anticipated camping in bear country.
CWO4
Hubert, NC
F250, FX4
DeltaBravo
DeltaBravo
Delta
MIKES MOM
  • Thread starter
  • Banned
  • #7
18 years in the army and counting. While I don’t disagree, I’d like to experience the finer things in life for a change
DeltaBravo
DeltaBravo
Delta
MIKES MOM
Thanks for the mock-up. This also happens to be my exact build!
if this is accurate, it looks good. I expected the length to be much longer
DC9atnight
Toyota Tacoma
All good points. One of the advantages of the RTT in my opinion is that it expands the available places to sleep beyond suitable tent camping. (In a pinch you can even sleep at truck stops, RV parks, or Walmart parking lots.) I agree about roof storage not being ideal but a slender hard shell RTT at 80lbs at least prevents me from being tempted to throw bulkier and heavier crap up there.
Squatch
Definitely had your share of the suck.
I've never slept in a roof top tent, so I don't know that it's a finer thing, but I use a blow up mattress in a tent unless I'm hunting... usually, I find some place with a cabin and ditch the tent anyway, haha.
I would probably just sleep in the front seat instead of lose payload for it.
Is there an option to have a normal tent secured to a roof rack and use a blow up or foam mattress to save weight? You'd have a bit longer set up time, but the weight savings could be worth it.
DaveH
I hadn't really considered the Walmart scenario. I suspect that if we are that close to civilization, we may spring for a hotel. However, I do anticipate that we will have 3, possibly 4, people on many of our trips so a RTT and a ground tent seems like a lot to bring. On the other hand, I've been contemplating options for 2 in a RTT, and 1 inside.
AcesandEights
Ace!
Oregon
DR650
When I realized the Bronco wouldnt support a RTT I nixed the idea. There are other things that need to go up top and that means the Bronco doesnt have the capacity for a RTT.
You can't have the weight of the RTT, with sleeping bags or sheets, and two people. Exceeds 450 lbs.
If you have an a/m rack, or light bar, lights, recoveryboards, just about anything, you exceed the weight limit.
