2-Door Wind Noise (Observation & Looking for tips & tricks)
Owl
G
Sacramento
White Wrangler JK, White Bronco Base 2Dr
I've have a late 2022 Base (white if that matters).
I have found that I get a wind-noise/leak sound on the driver's side if I leave the windows open a few inches for a few hours (on the driver's side specifically) if the Bronco is out in the sun on an 90+ day... AND THEN close the windows and drive.
After the windows are up for awhile (out in the sun)... everything seems to re-seat back to no noise & no leaks.
Anybody else experience this?
On another matter... there always appears to be a wind noise on the passenger side... and it sounds like its right in back of the passenger seat. Not a leak-noise... just a wind noise (if that makes sense).
Anybody figure out how to get this to go away, or at least minimize (without turning the stereo up!)
Thanks!
crzyhawk
Virgina
2024 Bronco, 2008 Mustang
I haven't noticed that issue, but I also have not experienced the use case you describe.
Dan-O
Dan
Fountain Hills, AZ
I have noticed that temperature changes must expand and contract the roof and or seals enough that I get new noises, wind , creaking, and rattles as seasons change. For me it always turns into an Easter egg hunt trial and error trying to track down the ever changing noises.
nwGTS
Nate
Chicago, IL
Thanks!
You're not crazy. I hear this same noise. What I believe to be the culprit is the seal where the two front panels and the rear clamshell meet. That strip of rubber sometimes is not seated flush creating an air gap or turbulence zone which we creates windnoise. I'll squish it flush and the noise reduces. Typing this out I think I might toss some painters tape over it one time to see if I'm right.
Bruzer22
CO
1968 Mustang, 2022 Bronco
If your panels don't sit flush all the way around, don't be afraid to adjust all of the mounting bracket locations. I went for a couple of years without doing anything and just living with wind noise, and finally adjusted all of the brackets. While there's no getting away from the typical wind noise of a convertible, it did cure the random noises that are not typical. Every singly one of the brackets required tweaking.
Ford Bronco 2-Door Wind Noise (Observation & Looking for tips & tricks) Screenshot 2026-08-10 at 10.27.01 AM
VirginiaHeritage
Frank
‘25 Bronco HE
If you haven’t recently cleaned and lubed your roof seals, that’s a good first step to cut down on wind noise.
Panels off, gently wipe down the seals on the front pillar, panels, and front of clamshell with a damp microfiber. Avoid heavy friction. Wipe dry with a clean one. Where the seals touch the underside of the hard panels, clean the contact lines on the panels the same way. You don’t need to be as delicate with the panels.
With everything clean and dry, apply a thin coat of Sil-Glyde to all seals. A little goes a long way. I put little dabs on my finger and place a dot of it every few inches along the seal. Then I run my finger up and down the seals to spread it evenly until the whole seal shines.
This maintenance will help quiet roof squeaks/creaks over bumps and wind noise on the road. Also the reduces the odds of rain leaks and extends your seal lifespan.
How often you need to do this depends on how often you run with roof panels off. Road dust getting on the seals makes them less effective at sealing.
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
Panels off, gently wipe down the seals on the front pillar and panels (top and bottom) with a damp microfiber. Avoid heavy friction. Wipe dry with a clean one. Where the seals touch the undesired of the hard panels, clean the contact lines on the panels the same way. You don’t need to be as delicate with the panels.
How often you need to do this’ll depends on how often you run with roof panels off. Road dust getting on the seals makes them less effective at sealing.
The best tip!
It also helps find sporadic water leaks you may have in the roof caused by ripped seals! Super fun! /s
Rydfree
Benny
Alabama
Thanks!
Are you hearing this passenger side noise from the drivers seat only ? Usually if there is noise from one side it's the other side that hears it more distinctly, just the way sound travels behind your head to the other persons ear. It probably is coming from both sides. If you have already sat in the passenger seat and determined that is where the sound is actually originating from then disregard this post, lol.
MayhemMike
Mercury
Turn up the stereo.
Owl
Owl
G
Sacramento
In regard to hearing it from some other place in the Bronco... the wife doesn't/won't drive my Bronco, and my arms and legs aren't long enough to drive from the passenger side (LOL).
My daughter has a Bronco... and next time she visits I'll let her drive mine and sit in the passenger-side and let you know. She drives a 4-door, so I can't ask her about 2-Door noise.
Owl
Owl
G
Sacramento
Let me know the results of the tape-test. I've also thought about doing this, but have been too lazy so far.
Rydfree
Benny
Alabama
I just noticed you have a 2dr. I made this video awhile back when I was tracking down the wind noise. I went back later and put actual rubber door weatherstripping in place of the piece of foam I used as a test
Maybe your noise is from same location ?
Owl
Owl
G
Sacramento
I tried this at one time, but I don't remember it providing that much relief. Maybe I inserted it wrong.
I guess I'll try and use blue masking tape on it, and actually see if that is the problem-area or not.
Thanks for the video though... very nice effects!
hutchman
Steven
OR
26 Bronco Base
It's a Jeep thing......oh wait, that's not right.
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
I have been planning to take the clamshell off and do the weatherstripping seen here:
https://www.bronco6g.com/forum/thre...-sound-aka-more-or-less-cowbell-please.53833/
I believe your wind noise (as indicated in the post above) is from that area. But in addition to putting weatherstripping on the outside the link above has some areas that you can also put strips that you cannot access with the top on that will likely create a good reduction in wind noise.
