2 Door Overlanding Suspension
ElDuderino
Ohio
23' Badlands
I've been doing some research into upgrading my suspension for the added weight of overlanding. Having a hard time selecting. I have a 2 Door Badlands with Sasquatch. I was leaning towards OME until I found out they don't make a kit for the 2 door. I reached out to ARB and they said they won't be making anything more for the 2 door . Has anyone upgraded their 2 door suspension specifically for overlanding/offroading? Looking for recommendations. Thanks.
MileHighCitizen
Al
Denver
Bronco 2D 2.7
How much added weight? What would be the difference in just using a 4-door suspension? AFAIK the difference is that the spring rates are lowered for the 2-door for the reduced weight. Seems like a 4-door setup would solve your problem.
Why not just use a 4-door Sasq suspension or something similar? You can probably find Sasq takeoffs for pretty cheap.
ElDuderino
ElDuderino
Ohio
23' Badlands
I don't have the exact weight added. I added overlanding accessories. I'm under payload, but I'm more worried about losing articulation & ride comfort while off-road. Roof rack, RTT, extra gas, traction boards, a fridge, storage drawers, cargo shelf, camping gear ect...ect. Eventually aim to add a winch to the front and a beefier fender.
Stage 3's website lists the Old Man Emu only fitting 4 door models, but ARB's website shows fitment being compatible with 2 door models. I've reached out for clarification. I'd have to imagine everything bolts up the same, the only difference being the 2 door is lighter so the spring ratings are for a 4 door.
MileHighCitizen
Al
Denver
Bronco 2D 2.7
From what I've seen around here, the 4-door will bolt up the same. The lift/leveling kits are the same, so I would assume the attachment points are as well.
If it was my money I would get a 4-door sasquatch takeoff suspension (i see them all the time in the marketplace on here) and call it a day. You'll save a ton and it will give you the extra stiffness without losing the OEM ride quality.
I also would consider changing only the front once you get the winch. As long as you remain under payload, you're gonna be fine in the rear. If you notice some sag or start hitting bump-stops when off roading then change the rear as well. Don't try to solve problems that aren't there. My $0.02.
Tricky Mike
21 Bronco
I've run 4dr springs on a 2dr. Not a huge capacity gain but it helps. Too harsh when empty though.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Wow… you’re basically driving a mOaR door. I’m quite surprised you allow these parts on your Bronco…
ElDuderino
ElDuderino
Ohio
23' Badlands
Thanks for the response. I would say a majority of the weight is in the rear of the vehicle with the drawer system/cargo shelf/ and camping gear. I'm considering just buying a 4 door sas takoff. I am also worried about ride quality once all of that gear is removed.
I got a response from ARB about the Old Man Emu kit, and they said technically the 4 door kit would fit the 2 door, but the springs are rated for the 4 door, so they have no idea about height gained or ride quality being on a 2 door as they have never tested it.
I am kind of torn on what to do.
Do you run a lot of extra weight? Have you hit bump stops or have extra sag? I too am worried about ride quality once I remove my camping gear ect. This is my daily driver as well.
Tricky Mike
21 Bronco
Never weighed it, just camp gear and whatnot a couple times a year. 200-300lb maybe? I took them off in favor of adjustable Eibachs because the ride was too choppy empty. Now I just crank up the rears another inch when needed.
ElDuderino
ElDuderino
Ohio
23' Badlands
Which kit did you go with? Eibach Pro-Truck coilovers?
Aonarch
Jack Hoff
MT
https://www.bronco6g.com/forum/thre...ide-lift-heights-with-wheel-tire-sizes.17719/
I second, or third going with 4Dr Sas springs.
I personally love Bilstein 6100s. You can grab a 4dr kit and then pick your poison of Bronco Sas springs from the Cook Book.
Tricky Mike
21 Bronco
Yes, pretty happy with them.
I must add, I had a double whammy, 4dr/V6 on a 2dr/L4, so if you have the 2.7 is will be slightly less of a jump.
ElDuderino
ElDuderino
Ohio
23' Badlands
I do have a 2.7
Going to continue doing research before I pull the trigger on anything.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I overland with a 2 Dr and haven't needed anything. I think if I loaded any more gear I would be over my GVWR!
Ford Bronco 2 Door Overlanding Suspension bronco6
ElDuderino
ElDuderino
Ohio
23' Badlands
Any idea what weight you're at? Or roughly how much junk you are carrying? I'm heading to Moab for 3 weeks in less than a month. Want to make sure I'm still able to do moderate trails without bottoming out.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
For the image (Poison Spyder/Moab) I had around 200lbs of gear, but for the trip I'd estimate 500lbs extra.
