2.7 engine cover installed
Ground_zero298
Scs michigan
Thanks to @JcrOffroad fir a great product.
Original thread
https://www.bronco6g.com/forum/threads/2-7l-and-2-3l-engine-covers-jcroffroad.56517/
Quality product. Easy to install, 3 mounts that screw into 3 open holes. Takes longer to find the holes than to install it.
I know everyone sees a engine cover. I see a spot to cook, reheat, defrost, and keep the coffee warm. Nothing some rivet nuts and a couple small cooking racks won’t fix. Gonna thermal it tomorrow. See what temp she gets up to.
I did paint mine, drilled out the mounts and added m6 rivet nuts for my thumb screws.
Thanks again for a out of the box product. Definitely gonna come in handy!
Ford Bronco 2.7 engine cover installed C4C60AAC-87EB-4930-85E1-DE58225046E5
Ford Bronco 2.7 engine cover installed A52DE95D-41B8-4DBB-923B-8A34ECC1E5BD
Ford Bronco 2.7 engine cover installed 61394B38-48F2-4086-922C-D0E429E4F895
Ford Bronco 2.7 engine cover installed B2B09418-DA7B-4711-AB84-8ADC09044549
Power Man
Sunbury, OH
Bronco Sport, F150, Mustang Conv, 69 Bronco. 62 Ec
I like it! , , , ,
RHeinz
Ric
Houston, TX
Doesn’t the hood cover the engine? As far as a cooking table, an Ozark Trials aluminum folding camp table is probably a lot cheaper and more functional.
Roger123
Roger
VA Beach, VA
Not when it’s open.
Ground_zero298
Ground_zero298
Scs michigan
I plan on cooking on it while I drive. Lot of folks do it. That’s where something in tin foil would be put on the cover. For cooking this will work just as well as my rear table for the jetboil setup but won’t take up any extra room.
Maybe call it the motor table.
zyglyrox
Cory
Cleveland
‘24 BB Sas / ‘21 Bronco Sport BB
Other than the 2.7 cutout into it I dig it.
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
That would look a lot better without the stickers, but...to each, their own!
JR
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
JR
Don't worry - The heat under the hood will likely change that soon enough.
Ground_zero298
Ground_zero298
Scs michigan
JR
I like to acknowledge the companies I support. I hate stickers on the outside. So I find a way to work them in. This build, they’re under the hood. If a couple get messed up will make some fun out if it about the sticker quality.
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
I get it. I put mine on my toolbox. It just looks really cluttered, so you covered up the cluttered engine bay with something to make it look clean, then made it more cluttered.
JR
RHeinz
Ric
Houston, TX
Haha, Wow! You both just brought back a lot of fond memories. Worked for the Arizona Highway Dept as an engineering aide on a survey crew in 1971 and 72 up in Arizona’s White Mountains. That was standard procedure to warm up lunch.
