2.3L 7MT backfires
MannyG20
Ted
F-150
I haven’t seen anyone mention this before so I thought I would put this out there.
I have a ‘22 Badlands 2.3L 7MT with 21k mikes in it. I do have Sport mode enabled via ForeScan. Recently when I am in Sport mode if I do a hard acceleration in 1st gear and get the RPMs up to 3.8ish I will get a backfire. It doesn’t do it every time but usually in the first few minutes of driving.
it just started doing this so I don’t have many details on when it does versus when it doesn’t backfire, only that it takes a hard acceleration and high RPMs.
Lowcountry Bronco
William
South Carolina Lowcountry
Backfire is rich air/fuel, makes sense you're seeing it on a cold start at WOT in sport though but would think the computer would catch it.
Either take it in to the dealer to look at it or modify your morning routine with a good warm up period before hitting the redline.
Ducati1098
Are you sure it’s a backfire and not a misfire?
Ogre
James
'23 BD 2dr 7MT CG, '18 Indian Chieftain
What he said. All EFI vehicles have a routine on startup. It'll run rich to protect the motor. You shouldn't be pushing a vehicle that hard until it's fully warmed up. Your backfire is driver error, not truck error.
MannyG20
MannyG20
Ted
F-150
I can accept driver’s error. (y)
Strizzo
Houston, Tx
Lexus GX460, 1966 Mustang Convertible, Jeep Wrangler TJ
it just got cold in texas, so the cold start fuel compensation is much higher than it has been when the weather was warmer. Also its not a great idea to run the motor hard before its warmed up.
Boostedblues
Kentucky
2016 Focus RS, 2011 F-250, 2004 Ranger 2016 Fusion
The 2.3L in the focus RS back fires. But the Bronco probably shouldn't. I have heard some broncos with the 2.3 with a slight burble maybe to make it sound a little more mean, of they may have had an exhaust.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
With the MRT Trail Rated Axleback, I get a ton of burble in winter running Normal Mode. Even a few little pops/backfires till it warms up.
If you are quick to clutch in(especially while cold) the engine hasn’t scavenged its cylinders fully, additionally it’s running a richer AFR… Sport mode will further increase the audibles due to the mapping on throttle lift off (cancelling the revhang/scavenging)
Add all of this up together and you’ll find a bit of extra noise comin out the tail pipe
