- Brian
- Sep 14, 2023
- 65
- 8,942
- 15,962
- Central CA
- '23 BB 4dr 7MT, '22 BSport OBX, '87 B-II XL
- Big Bend
Well I haven’t cracked the code on the Ford ECU to see precisely - but I think the level of detail you are talking about hardly matters unless you are doing custom tuning to try to eek every little bit out —- and if you are doing that - you likely aren’t skimping out buying pedestrian 87 octane on your tune.i ask because there are many different methods of engine management. Does the ecu use a rolling average to deal with timing? Maybe it doesn’t wait for knock before it pulls back, and instead uses a wideband o2, exhaust gas temp, and injector duty cycle to determine max power output before knock
modern engines are doing a lot more then what there were doing back in then90’s.
if we don’t know then let’s make it clear we’re just guessing.
