2.3 failures / issues. Post the issues you have had
Brettlil17
Brett
South carolina
21 f150
I’ve had mine going on a year. 15-16k miles. No issues up to this point. I have an older 2004 ranger non turbo 2.3 that gave me right at 200k miles before major failure. I believe it would have lasted longer but I got it when i was a teenager, gave it little maintenance and a lot of neglect. I had 3 valves break apart at once. I know it’s a different animal, but the base design is similar.
if you have have engine issues post it up, and please include the mileage.
thesocalexplorer
Southern California
approx 20k miles in and no major issues on my end. the only thing I can remotely think of is the coolant needing to be topped off a bit more than I'm used to, but runs strong.
markpilip
Kyiv ( #NAFO)
Ford Bronco
21 months. 26K miles. Zippy. Running like a top.
Charlesbrown165
Chuck
Johnstown, NY
2012 Jeep Wrangler Rubicon 2 Dr Cosmo Blue
2023 Black Diamond 4D non sas with 40k. Zero issues. Oil changes in the driveway every 5k.
2021 Ranger Lariat with the same 2.3…….90k…..zero issues
Fordified1
Bob
Mid South Texas
2015 2.3 Ecoboost Mustang. 100k miles still running strong. What makes you believe these engines have problems? because they don’t. They are bulletproof when not pushed to astronomical horsepower levels with huge boost and bigger turbos. Please show us somewhere you have seen someone bashing these tough little 2.3 engines.
Brettlil17
Brett
South carolina
21 f150
My post wasn’t to prove that they are unreliable. Just wondering of issues that people have had for reference.
I decided on this engine based on my past experiences with the older 2.3s. They all have been tough and lasted the duration for the ones I have had.
My opinion it’s the better choice between the two. I know it’s debatable but not wanting to get into that.
LT. DAN ICE CREAM!!!
Philadelphia, PA
2021 Badlands
'21 Badlands, had to have the turbo replaced at 17,500 miles. If the vehicle never went into limp mode for an ABS issue, it would have never been noticed because it was still producing upwards of 22 PSI of boost under load.
Vehicle is still in the shop for said ABS issue.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello! Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to see how I can assist you with your ABS concerns!
Bsenecal
Vermont
'19 Ranger crew cab, '17 Fusion sport, '68 Mustang
We also have a Bronco and Ranger,
2022 Outer Banks Sasquatch with 21k no issues and a 2019 Ranger lariat 39k also no issues.
orion
Jeremy
17' F-250, 17' Explorer
Have you looked at the valves to see how coked up they are or if at all?
Fordified1
Bob
Mid South Texas
Nope. It is a concern, and why I only use top tier premium fuel.
ChrisB351
Shreveport, LA
22 Black Diamond over 1.5yrs and right at 26k miles without an issue. Only had 2 problems overall. Just under 5k my driver front brake rotor was wearing like the pad was only making half the surface contact. Dealer did all new front brake pads and rotors. 2nd problem was the rubber trim on the window switches wore off. Of course that was covered too.
BigHoof
PA
Ram 2500
The oil you use is more important than the fuel. The fuel never touches the backs of the valves so really doesn't make as much difference as you think. Maybe carbon in the cylinder but not the backs of the valves.
lapazleo
2022 bronco badlands
Most folks don't seem to know Ford made two different 2.3's. The old 2.3 Lima engine in Pintos,Mustangs and Rangers has nothing in common with 2.3 Eco boost except displacement. I will say both engines proved to be reliable however.
