- First Name
- Curtis
- Joined
- Sep 16, 2021
- Threads
- 12
- Messages
- 970
- Reaction score
- 1,941
- Location
- Chandler, AZ
- Vehicle(s)
- 2022 Bronco Badlands
- Your Bronco Model
- Badlands
What is the benefit, if any, to using spacers instead of perch collars? From what I've read on here, perch collars change the static position of the shock, and may limit travel, though others have said the difference is negligible. Although the spacers lengthen the overall assembly, shock performance remains the same, right? As far as articulation goes. The spacers will give me some more tire/fender clearance, but do I gain any articulation by pushing the suspension down? Perhaps by moving the tires further away from the fenders, I have less chance of stuffing the tires in the fenders, possibly freeing up some articulation, instead of running out of space?A perch collar lift does not lengthen the strut assembly over the stock length.
A spacer lift does lengthen the strut assembly.
Using the spacers for any lift over 1" level is not the best way lift an independent front suspension.
Keeping as close as possible to the factory(engineered) halfshaft angles and tie rod angles is extremely important......you can't do that with a big spacer lift(top and or bottom of strut) on an independent front suspension. The factory shocks just aren't engineered for the larger, or actually any lift.
A 2" perch collar lift is about the max you should go without adding new upper control arms that will allow more alignment adjustment to keep your alignment in specs.
I know "people do it all the time"....but that's not a good reason.
If you're just doing it for looks....go for it, but realize that the aforementioned axle and tie rod angles are extremely important.
