swamp2
@swamp2 I had peak charge temps of 177* after a 0-100ish pull. Ambient was 70ish. This was on the 93 tune If I recall as well.
Thanks. Do you know what it is yet with Whipple IC? Did you look at COBB, they look really nice.
Spooled
Republic of Texas
It's arriving today, but I may not have time to get it installed until next week.
Didn't look at COBB. They quote similar increases in volume, though. It's a little more expensive, but they make good stuff. I had a Cobb IC and other COBB goodies on my Focus ST back in the day that worked well
vrtical
Doug
GSMNP, TN
Fords
I ran a 13 ST with a Cobb Accessport E30 setup with a Steeda Street comp FMIC which is a CPE. Any upgrade is going to be a good upgrade, the Ford coolers are garbage.
MWILD
2022 - BB Sasquatch - Mid - 2.7L
Nice! Get a chance to do any Dragy pulls yet or are you gonna wait until the IC is installed?
Spooled
Republic of Texas
hmm, $2300 for a tune is not for the faint of heart.
you can spend $950 for 60hp (whipple) or that for basically 200hp. It’ll be cheaper with a used ECU as well 👍
You also lose your stock file with the whipple tune because the device doesn’t store it. That was a hard pass for me.
Spooled
Republic of Texas
id like to get some before. Still need a dragy 🙄
swamp2
I still have weird part throttle 4-5 shifts sometimes in sport mode. I need to log it and send it over and see if Adam can fix it.
Extremely interested in this. TIA. Don't you also get it 5->6, perhaps a big less severe? It's a thunk/thump, right? As I noted many Raptor owners have observed this.
Any updates here @Spooled ? TIA.
Spooled
Republic of Texas
No updates as I've been slacking on sending over some logs to Adam. Will get that done today/tomorrow for sure
Whipple IC is in and it's helped for sure.
I've seen a 50* drop in charge air temp at the end of runs.
I got a dragy too, but have been having issues with it acquiring enough satellites to get a valid run in. might have a faulty unit.
swamp2
Wow, 50°. That's huge. Which intake sensor? Are you sure that's "apples to apples"?
Spooled
Republic of Texas
I saw the 50* drop in worse weather, actually.
I'll have take a look at the log again and see which channel it is exactly.
Charge Air Temp on the screen shows nice improvements also. I think that's what it's called though the UI options
Turbo yzel
DMV
Braptor
Wow 50* is a lot
any thought on downpipe too ??
Or stock ones on for stock size turbo ?
Spooled
Republic of Texas
Wow 50* is a lot
I plan to add downpipes too, but holding out for some cheaper options (hopefully from CV Fab)
vrtical
Doug
GSMNP, TN
Fords
not shocked at all, like I said the stock cooler is garbage. you can compare IAC to ambient and see the real benefits. You can always use the Torque OBD app and get a bunch of info also.
