tstaff
Todd
Brandon, MS
2024 Bronco Badlands, 2023 Honda Accord Hybrid
We need more convos about fitting Sasquatch tires on non Sasquatch broncos, 2.3 vs 2.7, 2 door vs 4 door. Did I miss any beat to death topics? OP had 4 different tire threads 🤣
Awwww....you missed the hard top vs soft top debate. :D
Jason519
Alabama
F150 4x4
Unpopular opinion: Stop putting E-load tires on your daily-driven midsize rigs. 🛞💥
E-load tires are designed to carry massive towing weights on heavy three-quarter-ton heavy-duty trucks. When you put that ultra-stiff carcass on a lighter midsize truck or SUV, a few annoying things happen:
  • Your suspension can’t compress properly over small bumps, giving you a harsh, ride on the highway.
  • The extra rotating mass saps your acceleration.
  • Your gas mileage takes a nosedive.
When you pull up the data on SimpleTire, modern C-load and Standard Load tires put up with the abuse just fine.
Falken Wildpeak A/T4W
Known for its legendary durability, opting for the lighter load ratings allows the tread to naturally conform to trail obstacles when aired down, resulting in an exceptional off-road score without punishing your daily commute.
BFGoodrich All-Terrain T/A KO3
BFG explicitly redesigned the sidewalls on the newer KO3, which gives you extreme splitting and bruising resistance on the trails even in lighter load configurations, matching the ruggedness of older 10-ply designs without the heavy weight penalty.
Unless you are constantly hauling a massive overland trailer or carrying a full steel armor build with a rooftop tent, steel bumpers, and a heavy drawer system, a C-load or heavy-duty SL tire is going to give you better traction on the trail
Drop your thoughts below. 👇 Are you team "Heavy Duty E-Load or Bust," or have you made the switch to a lighter, smarter trail tire?
View attachment 811543 View attachment 811544
I agree I only run c rated
BigShan808
Hawaii
2022 Bronco OBX & 2021 FX4 STX F150
Could gaf! I put on what I like.
rdg04578
Everglades
Bob
Northern Maine
2013 jeep rubicon, F-150
Everglades
Yup that's what a lot of flatlanders think when they come up to northern Maine and run the logging roads with C rated tires--all we ask is please bring plenty of plugs and a good plugging kit--and pull far enough off the road while your plugging them so we can get by.
23OBX2.7
AB Canada
2023 Bronco
Also several spares for ripped / punctured sidewalls!
