OracleLights
New Orleans, LA
www.oraclelights.com
Crushed Quarter Panels. Missing Bumpers. Functioning Taillights.
What the 2026 King of the Hammers Revealed About Lighting Durability
Ford Bronco A Real-World Durability Test You Can't Replicate in a Lab! ORACLE Flush Taillights on KOH-Winning Bronco Raptor IMG_9691
The Ford Performance Bronco Raptor, driven by off-road legend Brad Lovell and co-driven by his son, Adam Lovell. Looking at the extreme body damage on the rear corners, you are looking at the aftermath of the 2026 King of the Hammers Every Man Challenge. This single race is universally regarded as one of the most punishing single-day off-road events on the planet, combining high-speed desert wide-open sections with near-vertical, boulder-strewn rock canyons in Johnson Valley, California.
Ford Bronco A Real-World Durability Test You Can't Replicate in a Lab! ORACLE Flush Taillights on KOH-Winning Bronco Raptor bronco_koh1
Photos: Ford Performance
The Finish Line Reality
Brad and Adam Lovell put on an absolute clinic in this exact truck. They took home first place in the Ultra4 4600 Stock Class and an incredible second place overall for the entire Every Man Challenge event. The staggered starting positions meant they had to fight their way through traffic, hunting down and passing heavily modified, custom-built unlimited cars from higher classes while piloting a production-based truck
Ford Bronco A Real-World Durability Test You Can't Replicate in a Lab! ORACLE Flush Taillights on KOH-Winning Bronco Raptor bronco_koh2
They crossed the finish line with an official time of 6:27:53, beating the second-place Ford Performance team by more than 36 minutes. To grasp how brutal the environment was, out of 24 vehicles that started in their class, only 5 actually survived to see the checkered flag. The rest were taken out by mechanical failures or the unforgiving terrain.
Ford Bronco A Real-World Durability Test You Can't Replicate in a Lab! ORACLE Flush Taillights on KOH-Winning Bronco Raptor bronco_hoh4
Understanding the Truck Build
Because the Lovells run in the 4600 Stock Class, the rulebook forces the vehicle to stay remarkably close to what rolls off the assembly line. The rules dictate that the vehicle must retain its full factory body, run on 35-inch DOT-approved tires, and maintain the stock suspension geometry pivot points. The tires you see strapped into the back in image.png are the exact 35-inch mud terrains mounted to beadlock Method Race Wheels that clawed their way up infamous obstacles like Chocolate Thunder and Jackhammer.
The striking blue-and-white factory livery with the bold Raptor branding across the rear panels was a special design used by Ford Performance to celebrate the anniversary of the Raptor nameplate. Underneath that wrap is the raw engineering that allowed the Lovells to fly through desert whoops and maintain composure when wheels were lifting off the ground.
Ford Bronco A Real-World Durability Test You Can't Replicate in a Lab! ORACLE Flush Taillights on KOH-Winning Bronco Raptor bronco_hoh3
The Tail Light Carnage Connection
The severe damage to the rear quarter panels in these photos tells the real story of the race. When you are forcing a full-size vehicle through narrow, jagged rock slits, the rear end of the truck inevitably becomes a battering ram against the boulders. The factory sheet metal is completely caved in right around the light housings, and the rear bumper structure has been torn away entirely, leaving the stamped 4621 license plate dangling underneath as seen in this image.
Ford Bronco A Real-World Durability Test You Can't Replicate in a Lab! ORACLE Flush Taillights on KOH-Winning Bronco Raptor IMG_9690
Standard, protruding factory plastic housings simply wont survive this type of physical abuse. When a truck drops off a ledge and pivots into a rock wall, fragile lighting structures shatter instantly. This exact kind of structural mechanical trauma highlights why serious off-road builds require flush-mounted, highly durable aftermarket lighting solutions that can take a direct smash from a rock and keep right on illuminating the trail through the dust.
Tybh88
Tyler
"rear bumper structure has been torn away entirely" 🤔
jofer
Joe
Salt Lake City, UT (prev Houston, TX)
'21 Bronco Sport, '23 2dr Bronco Badlands+Sasquatc
I'll ask the dumb question that is probably answered elsewhere already.... Is that a DR rather than a raptor? Or just a very custom 2-door build with a raptor label on it?
Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
So they worked for a week?
It's the 2 year mark that buyers are complaining about
Steve_In_29
St Johns, Arizona
Not long enough to be a Raptor or a DR.
Just a regular 2 door that they slapped a Raptor sticker on
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
Not just a regular 2-dr. It leverages the 2-dr frame/body panels, but that is the only resemblance to a regular 2-dr. It is a one-off build.
BAUS67
redneck
Central PA
Technically the "4600" Bronco goes back to this...........
https://www.bronco6g.com/forum/threads/ford-performance-debuts-bronco-4600-race-trucks.12269/
.......which Brad's Bronco is one of. Here is a more current thread from @NORCALGXP about the current "4600" livery..............
https://www.bronco6g.com/forum/thre...ammers-koh-every-man-challenge-2-6-26.128467/
Lovell also pilots a DR for Ford as well. The DR is a 2DR with a 4DR wheelbase. AND a Coyote!!!!!
SCORE Journal - SCORE-Journal-DEC-2024
And finally .......Yes, it is just a 2DR 4600 Bronco with a BRaptor sticker on it. :wink: That's big business for ya........ show you something cool even though it is unobtanium to lure you in.
BAUS67
redneck
Central PA
Those widdle wocks are hee-larious. :ROFLMAO: 🤔 🤘 🤣
Should have backed it up about 6" , would have given the suspension some articulation.
Montana Bronco
Montana
Chevy
Nice to see a Raptor without the hideous fender flares. 😎👍
BigMeatsBronco
Allan
2021 FE 2 door
The RULEs also say " no modification of the body mounts to the frame, or relocation of the body mount or changes to the body mount to the frame"
Yet EVERY winning Ford Bronco has the Front body mounts chopped off for tire clearance, and heavilymodified!!!..ROFL... if I was one of the other teams, I would be raising this concern. Funny how the the biggest sponsors get to bend the rules in their favor. I brought this up to one of the judges at K. O..H, and he didn't have a real answer. 🤣😂😀
I specifically left these alone and unaltered, just in case I wanted to race in the future, and ALL for nothing. Since they don't follow their own rules.
Ford Bronco A Real-World Durability Test You Can't Replicate in a Lab! ORACLE Flush Taillights on KOH-Winning Bronco Raptor Screenshot_20260607_093333_Photos
Looks like kid built them...lol
OracleLights
OracleLights
New Orleans, LA
I always thought racing was about finding creative ways to work around the rules until they write new ones anyways! 😅
