- Camburg
- Apr 16, 2025
- 21
- 32
- 122
- Huntington Beach
- 2020 Ford Bronco
- Badlands
Our new Camburg Trail Series long travel kits for the Ford Bronco bridge the gap between daily driver and race vehicle. We designed this kit with the ability to build up your Bronco in stages or all at once. Whether you’re out exploring the trails in MOAB or wide open down in Baja Mexico, this is the kit that takes your Bronco’s suspension to the next level. Wanting to gain wheel travel, articulation and stability, we went 2” wider per side. Utilizing the OEM or aftermarket fenders, you’re able to run up to a 37″ tire without limiting wheel travel or turning radius. The kit is designed to use readily available bolt-in OEM style aftermarket 2.5/3.0 coilovers. So, if you want to build it up in stages or if have already lifted your Bronco with coilovers, you can use them with this kit. We recommend extended travel coilovers for maximum useable wheel travel.
Bronco Long travel kit
Shop Camburg Bronco/ Bronco Raptor Suspension
